Tuck or untuck micro switch cable
Should I be pining the micro switch cable under this clap or is the clamp to hold ONLY the switch in place..and let the cable just hang loose?
Old 07-31-2022, 09:01 AM
proporsche's Avatar
it is for the cable
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-31-2022, 09:05 AM
thanks, seemed little awkward bending wire to fit in. And I tried attaching it to the handle outside the door THEN putting the door handle on..wouldn't fit through the door handle opening with the switch already attached. How can you clamp the wire on while its inside the door! the screw is tiny and no room to maneuver!
Thanks again
Old 07-31-2022, 09:11 AM
proporsche's Avatar
you attach the cable on the handle outside after you put it in the door..
Ivan
Old 07-31-2022, 09:26 AM
proporsche's Avatar
here is a pic..i just assembled it for you from my parts..
Old 07-31-2022, 09:56 AM
little confused..
did you mean, put it on outside the door “then” put it thru the hole with the switch already on?
also do you have any censors for sale in your parts?
Ivan
Old 07-31-2022, 12:06 PM
