72 mfi o2 sensors
What is the best location for O2 ssnsores? Kn the muffler after at the connections or on the header before the connections?
About 4 inches downstream of the collectors. Clocked somewhere between upright and horizontal, but not below horizontal or the it may be damaged by temp swings from water condensation.
Wideband O2’s don’t like rapid temp swings. Also very important to use the deep bungs, so it isn’t protruding into the exhaust stream or it will die early from overheating. |
Thank you
02 sensor
Bob |
Yes. Narrow band O2 sensors aren’t as fragile and sensitive to sudden temp changes.
Plus the O2 is before the cat. |
| All times are GMT -8. The time now is 02:32 PM. |
