-   -   FEBI - anyone running their timing chains? (http://forums.pelicanparts.com/porsche-911-technical-forum/1123799-febi-anyone-running-their-timing-chains.html)
Discseven 08-01-2022 11:15 AM
Am considering getting into FEBI timing chains. Thought to solicit input on them before pulling the trigger. This brand is part of the Bilstein Group. While that says something, I'd prefer knowing others are running these chains without issue---or with issue if that's the case.
RDM 08-02-2022 10:55 AM
I'm gonna take that as a no :-)
I've used a number of Febi parts on my old Mercedes and been satisfied.
That said, what could go wrong should a timing chain fail?
Discseven 08-02-2022 05:35 PM
"No" it is! Appreciate the comment re your Benz RDM.
Chain fail... fine word for that happening is 'catstrophic.' 'Expensive' also comes to mind. Basically sycronization between the valves and pistons comes to an end. So lots of things crashing about. That's not to mention what the loose chain will do.
RDM 08-04-2022 11:26 AM
Karl,
You've always been a risk taker and an experimenter- before I opened this post I was sure you were going to go for it!
Jeff Alton 08-04-2022 10:13 PM
Febi, a known good brand and OE supplier. Why are you asking? Only part available or 5 bucks cheaper?
Cheers
Discseven 08-05-2022 03:22 PM
Originally Posted by RDM (Post 11761338)
Karl,
You know me well RDM. I do plan to dive in... but would put the brakes on were there any screamingly bad news.
Cheers
Jeff... I ask having never come across the Febi brand before. Reason to consider this alternative to Iwis is indeed price. Iwis chain can be had anywhere from $57 to $100. Why pay $100? Febi chain... $30. Is paying more worth it? Personal call I believe. In any case, few dollars on one part one way or another is inconsequential. I'm into a rebuild here. You know thousands are heading out the door to support this cause. Makes sense to me to give as much business as possible to businesses that make a point of being price competitive.
My favorite price point comparison... our idle control valve. One can buy these anywhere from $1,100 to $47. (There's not much inside these.)
Jeff Alton 08-05-2022 08:14 PM
You will be fine with a Febi chain. Good/Great products. Iwis is likely the gold standard, but nothing wrong with a Febi what so ever.
And yes, I hear you on the ISV question.... :)
I totally get your question, just asking for clarity.
Cheers
Discseven 08-06-2022 09:38 AM
Cheers
Read your website Jeff. Powerful statements throughout. In a world of marketing BS, it's a challenge to know who to respect, or otherwise. Would be great if you were a short, few tight turns nearby. I'd be there... to get to know you---to confirm the man being more than the words. I shall trust you are.
Damm fine message/website. Most of all: fine story about you & Dad.
PS - Febi chains ordered. Input appreciated :)
eastbay 08-07-2022 06:44 AM
I put some new Febi chains in a 2.7 build around 10 years ago, lots of revs later still good
Discseven 08-07-2022 07:57 AM
Appreciate + comment Eastbay.
Jeff Alton 08-10-2022 06:44 PM
Karl,
Thank you for the kind words.
Cheers
