Intermittent noise from front frunk
So I have been having this intermittent noise from the front. It seems to only start making the noise when the engine is hot and when the outside ambient temp is hot. When I took the video I had done a short drive in a very leisurely fashion. I do not have the AC on and it was very hot out. I pulled the fuel pump fuse and the sound stopped, but so did the car and so I’m not sure that is what is making the noise. I would think it would be more consistent noise if it was the fuel pump. Any thoughts? https://youtube.com/shorts/WhyzcApEoi0?feature=share
Thanks |
I also think it maybe the fuel pump, and I'm thinking it may be vibrating against the metal skid plate. Hence the noise travel. Good luck.
| All times are GMT -8. The time now is 06:42 PM. |
