930 slantnose to frog eye conversion
Hi Pelicans,
In the final stages of getting my 930 turbo sorted out from a aftermarket slantnose conversion and boxed rockers to OEM fenders and rockers. I ordered the end caps, part: pcg-559-941-04. However the fitment of the rocker panel end caps seem way off. Any advice welcomed. ![]() ![]() Sent from my iPhone using Tapatalk |
Wrong End Caps.......
The end caps you got are for SC/Carrera cars (non-930 bodies).
Tony |
Hi Tony,
I suspected that too. But the packaging they came in say it’s the part number for the 930. Sent from my iPhone using Tapatalk |
Nothing a hammer/drill/black spray paint can't fix.. sweet rufs!!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Hoping I can get the correct part if anyone knows the correct part number.
'82 SC TL
I thought end caps are all the same (of course left & right versions) but only the boxed rocker caps were different
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Same here
RGruppe #180 So many cars.. so little time!! |
Do you happen to know the correct part number(s) for the 86’ 930? I thought I ordered the right one. Sent from my iPhone using Tapatalk |
