-   -   Tow hook issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1124211-tow-hook-issue.html)
89TRBO 08-08-2022 11:52 AM
Tow hook issue
Hello! New member here, with a tow hook question:
I'm parked in a garage underground, and my '89 930 needs a tow. The factory tow hook (right side pictured) is flush/at the same level with the bottom part of the valence/front lip (ie. same distance from ground to both).
I'd love to tow/pull it out of the garage (uphill for a bit) without damaging the valence, but don't see that happening as we go uphill. Is there anything out there/a tow hook that addresses such a thing? I've seen 911 bumpers with attachment points for tow hooks on the outside, but mine doesn't seem to have this sort of an option/no pre-drilled hole. pictures attached. Thanks in advance!
