What kind of gas tank is this?
I'm working with Len to rehab the fuel lines on my new to me 911L and he asked for pics for all of the fuel line runs. The car has always had Weber 40s on it so just a single line running back from the tank. Anyone know what the plugged end is for? Is this a tank from a later model? Thanks!
Old 08-11-2022, 07:25 AM
Red Line Service
Marc Bixen's Avatar
Looks like a 911SC or 3.2 Carrera 78-89????
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 08-11-2022, 07:31 AM
The plug at the bottom of the fuel tank is the tank fuel filter. Use a 22-mm hex or 7/8” hexagonal head bolt (double nut) to remove this plug.
Tony
Old 08-11-2022, 08:20 AM
It’s a later fuel injection tank noted by Marc
Bruce
Old 08-11-2022, 08:22 AM
One thing's for sure--it's not from a long hood car, as they never used the compact/collapsed spare tire.
Old 08-11-2022, 12:48 PM
Thanks all for the info!
Old 08-11-2022, 01:13 PM
If you want more volume and don't care about originality, it will fit fine. The blocked off hose went to the fuel pump mounted behind the tank. That's the proper outlet.
206 637 4071
Old 08-11-2022, 06:51 PM
BoxsterGT's Avatar
Porsche Crest
Unfortunately this is using the Return fitting, not the supply, so no benefit of the factory screen filter that is inside.
Len
Old 08-12-2022, 10:56 AM
