Senior Member
Suspension Question / Help
I have a 78 911 and in the next 6 months or so I want to redo the suspension
I will be replacing shocks (plan on Bilstein Sport) I currently have Boge
I want to replace all bushings. The car has ~ 94,000 miles. I was skimming over the Elephant site and I am interested in the Poly Bronz bushings
Do you use Poly Bronz and the mono balls together or no.
Looking for a nice stiff ride with some tracking and autocross thrown in.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 07-14-2004, 09:17 PM
Az911's Avatar
Send a message via AIM to Az911
You can use the Poly Bronz bushings with or without the mono balls.
If you have the funds I would do try to do everything at the same time. It keeps you from having to do some work twice
72T RS look
96 993
Old 07-14-2004, 09:31 PM
Designer King
Paulporsche's Avatar
If you do a search, I think you will find that many are using a combination of the sports and the heavy duties--one type on the front and the other on the rear. It might be worth checking out.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-15-2004, 04:13 PM
Driving member
jester911's Avatar
Bilstein sports in the front and h/d shocks in the back is the combo I just did and it is great.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 07-15-2004, 04:50 PM
