 A tale of two TTS’s
		Tested my original (I think) TTS last winter while the engine was out. It showed continuity across the W and G terminals but was stuck closed. Even heating it to 90C it still would not open. Did it again today with same results.
	http://forums.pelicanparts.com/uploa...1660754643.jpg So I bought a a new one and put it in. Looks a bit different but its listed on Pelican Parts as the correct part for my car. Has the same 45C temp spec on it. Cannot remember if I tested it prior to install. http://forums.pelicanparts.com/uploa...1660754717.jpg Now, 8 months later, troublshooting a hard cold start, I never considered this part would not work because it was brand new. Now I am not sure. Measuring across W and G I get nothing, no continuity or resistance when cold (32C) with it installed as in the picture. I even iced it down for an hour to try and force the thermal switch to close. Nothing changed. No continuity. http://forums.pelicanparts.com/uploa...1660755047.jpg Of course its an electrical part so no returns. Should I bother to look for voltage at the CSV or is this TTS dead too for sure? Darn things are pricey. Thanks  |
 Anyone?
 Here is a link to how TTTs work; not from a 911 but similar.
	https://www.sw-em.com/bosch_d-jetronic_injection.htm#Thermo-Time_Switch Roy  |
 So I would expect continuity between G and W when cold. You could try connecting W and G with a jumper lead and see if the car starts from cold as long as you don't operate the starter for too long. If the car starts you have your answer.
	Roy  |
 So the VDO TTS lasted 40 years and the aftermarket one lasted less than a year. Crazy. Thanks  |
 Checked the TTs on my car (1978SC) this morning and when cold I have continuity. Took it for a short drive and then afterwards with a warm engine there was open circuit between W an G, so looks like your TTS is broken.
	Roy  |
 Borrow your TTS........
		Neil,
	I have a TTS tester if you like them tested and evaluated. Will return them back to you via Priority Mail the day after I received the package. It would only take a minute to do the test. PM me if you are interested. Thanks. Tony  |
 Thanks Tony. PM sent
 TTS Bench Test Results..........
		Neil,
	Here are the test results: http://forums.pelicanparts.com/uploa...1661695897.jpg The TTS on top is GOOD. While the other one at the bottom of the picture failed the test. This one is always open for a long long time. Did not bother to find the duration of on-time. Will send them back to you tomorrow. Thanks. Tony  |
| All times are GMT -8. The time now is 06:38 PM. |
