Gas smell in car
I have a 1970 911T that has been converted to MFI with a single fuel pump in the rear.
The hoses from the tank to the firewall look new and also the hoses from the rear firewall to the pump look new.
I do not have any gas smell coming from the frunk or from the engine compartment.
When I open the car doors, I can definitely smell gas. Any ideas on where to start?
I have two return lines coming from the pump and both terminate at the rear firewall with clamps. I assume there is a metal bridge there and somewhere the two return lines get converted to a single return since that is what comes out of the front firewall, a single return to the tank.
Is there a Y somewhere inside the tunnel?
Thanks.
Old 09-28-2022, 12:07 PM
Check for fuel in the tunnel or at the tank exit
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 09-28-2022, 02:12 PM
HarryD's Avatar
This thread may be helpful (look for posts by Grady Clay): Fuel tank venting system question
Also this one: https://forums.pelicanparts.com/porsche-911-technical-forum/1114184-renewing-fuel-evaporation-system-70-911t.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-28-2022, 06:52 PM
All the fuel vapor system has been removed and plugged so it's not the source of the leak. It appears I need to go inside the car and inspect the lines in the tunnel since the only smell is coming from inside the car. I'll update on what I find.
Old 09-29-2022, 08:19 AM
HarryD's Avatar
This is not good. Your fuel tank needs to be vented to allow air to enter and leave so you do not collapse the tank as you fill or use the contents.
Where is your vent?
Harry
2020 MB E350 4Matic
Old 09-29-2022, 09:57 AM
