Designer King
Paulporsche's Avatar
More Fuel Accumulator Questions
My car is a 77 but the engine is from a 1980 SC and has been enlarged with 98mm pistons.
I want to replace my fuel accumulator, which looks like it is similar to the 2.7L version, since there is no lower return line. However, there is a port there with a nut on it, but the bottom of the port is closed off. I'm thinking I should replace the existing with one from a 1980, which would have the open lower port and return line.
If I go with the correct version, what do I need in addition to the accumulator? Can someone direct me to the part number for the lower line and to where it returns? Does it go back through the underside of the chassis to the fuel tank? Right now it looks like I don't have that line or any connection to the tunnel line.
Is there actually some advantage to having the return line? Or can I stay with my original configuration? If I stay with the original config, should I get a 77 non return version or go with an 80 version and plug the lower port as it is now?
Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-23-2022, 07:14 AM
Either should work from what I’ve read. The two top hard lines return to and from the gas tank. My 77 has the bottom line T-fitting and braided hose attached but not sure where it leads, it’s not band clamped so its not under pressure like the two top supply lines. The bottom line I believe is an overflow should gas get past the diaphragm. I really need to get busy replacing these lines !
Here’s an old link that explains FA function and testing -
Fuel Accumulator Test.... Show & Tell.....
Old 08-23-2022, 10:50 AM
Designer King
Thank you EC900!
After seeing your pic I went back and checked the bottom of the accumulator and I have the same configuration as you. I missed the line off to the side of the bottom port in the darkness. I should have removed the heating duct.
So it looks like I just need the 1980 accumulator after all.
Paul
Old 08-23-2022, 11:10 AM
