Oil leak experts?
I have oil leaking from a couple of the threaded studs that hold on my sump plate. Any suggestions on how to fix? Thanks
Yep, when you change your oil, drop that sump plate as well. The best known method here is to double up the gasket that goes under it when you reinstall. I think Pelican even recommends two of them when you select the product in the catalog.
Steve '66 912 - Polo Red; '74 911s - Silver Carrera RS clone '77 911s - Peru red IROC Clone '89 964 C4 - Guards red |
there should always be 2 gaskets...one above the strainer plate and one above the strainer..plus use the silicone nuts and aly washers
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thank you!
it is ok to use the sealant...but i have never had to use any...mainly use silicon nuts and alu washers
Ivan
Targa_PB_78_SC
I cannot tell from the picture, but I think the drain plug is supposed to be at 3 o'clock if you are laying on your back looking up at the plate. It points towards the 1,2,3 bank. That way the suction tube fits in the recess and the hole in the screen.
BareRearedRookie |
Thanks, so the drain plug should be rotated 90 degrees to the driver side and not towards the back of the car as pictured?
New-ish 911SC Targa Owner
Use brand new nylock nuts. A couple of those studs thread all the way thru to the sump and oil will travel down the threads. Only way to stop it is with the nylock sealing it on the threads.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
I have the nylons nuts, thanks.
Targa_PB_78_SC
Of course the hole in the screen has to go with the pump suction tube.
BareRearedRookie Last edited by mike sampsel; 08-25-2022 at 04:06 AM.. |
