-   -   Post-Rebuild Pre-Start Compression? (http://forums.pelicanparts.com/porsche-911-technical-forum/1125158-post-rebuild-pre-start-compression.html)
David Inc. 10-11-2022 07:45 AM
Originally Posted by 911 SLANT (Post 11818893)
I was always told to do leak down with motor hot and after rings have seated. Is this not true?
I think my results were much higher than they would have been hot with the engine fully oiled up, but it helped me to identify inconsistencies between cylinders. When 1, 2, 3 and 5 were all the same at just under 20, but 4 and 6 were ranging from 40-60%, big difference!
911 SLANT 10-11-2022 07:54 AM
You have some very knowledgeable mechanics chiming in on your post Jeff, Ian, ect..Your in good hands.
Jeff Alton 10-14-2022 02:55 PM
Ideally, yes. But we leak down the motor to ensure all went well, no broken rings, and valves are seating. Even cold with no miles we see leakage of around 6-12% which tells us we are good to install and start the break in process. Its a quick check to ensure all assembly steps up to that point went according to plan....
Cheers
