long warm start 1976/82 911S/C
1976 911S targa with 1982 3.0 engine/drive line.
engine 250,000 miles plus.
cold engine starts fine and runs great. hot engine starts fine and runs great. however there is a period between recent running and totally cold where i have to crank for 30 seconds. also, leaving the car parked with the engine end in direct sunlight, hot afternoon, affects the timeframes involved.
I have concluded that with the extreme mileage, the mass air flow sensor is probably unaffected by cranking, so I am trying to start with just idle/stop bolt fuel injection plus the cold start sensor injection of fuel.
when cold or cooled off, the cold start sensor kicks in and off i go. when warm, long cranking period ensues.
I am thinking that a higher temperature cold start valve might be available. OR maybe I put a different injector in there and operate it with a homemade "cold start/choke switch" anybody else encounter this problem, or have ideas to solve it?
Old 08-29-2022, 08:50 AM
Hi Don, I can see this is your first post. Welcome =P
In your case, i am thinking your rest/residual pressures either for your control/system are out of spec, or may be the accumulator.
However there is really only 1 way to tackle CIS troubleshooting....
(A) do all the basic checks in the factory Porsche manual, there are a few things to go through before you get anywhere near point (B)
(B) check your control and system fuel pressures for warm, cold and rest/residual.
Then you can have a logical thought process in terms of finding a problem. There is a test on the accumulator, but off hand I cannot remember it, but I am sure someone will point you in the right direction shortly.
Old 08-29-2022, 11:33 AM
