-   -   Advice on 8” front flare to compliment 9” rear SC flare (http://forums.pelicanparts.com/porsche-911-technical-forum/1125269-advice-8-front-flare-compliment-9-rear-sc-flare.html)
DoMeister 08-26-2022 04:24 AM
On 1982 911sc Targa
I have always thought the Targa benefits from a wider stance, it reduces the height to width ratio that impacts the Targa silhouette more so than the coupe….
That being said; I’m reasonably happy with the SC rear for now but I’d like to give the front more shoulders if you get my meaning.
Current SC stock setup is 7” front and 9” rear and I’m backdating the hood and bumpers. Front spindles lowered 19mm
Turbo & ST fronts are 9” which I think will create an unbalanced appearance IMHO. I’m not likely to change my 16” fuch setup so I’m looking for the subtle 1” difference to the front end that gives a little more curve and stance.
There are 3 parts to this question;
  1. I have never found a steel 8” front flare, how would one achieve this mod?
  2. What advice would you have on matching lips front and rear?
  3. Are there any pics of this approach?
Thanks all for your help…
chrisbalich 08-26-2022 04:46 AM
Your point about height:width ratio is why I keep thinking about doing a full turbo-body on my SC. I've looked into a lot of options. Here are my initial thoughts.
1. I reckon you'd need an experienced panel-beater to metalwork the front arches to extend the width without completely re-profiling the arch.
2. Do you mean the lips on the wheels? Like a square setup?
3. Pics of someone with 8/9 flares? Not that I'm aware of.
DoMeister 08-26-2022 05:25 AM
Chris,
It seems like an obvious mod to an SC but maybe there is an obvious reason why not to do it, would love to see some pics…
By lips, I meant the flares, some are rounded and others square off like the turbo flares. I had thought of turbo flares all around but decided against it for the moment. ST are another option but 4x the price for no apparent reason….
I have spent huge bucks on rust removal and my welder is sick of my face now after a year of surgery.
One solution I thought might work (reluctant to provide solutions before hearing from more experienced builders) was to fit turbo front flares, then run a one inch line inward of the lip and fold at that point. I’m guessing the shape would need some work but it could also be the case that the opening is just too big with this approach…. Help needed
Dpmulvan 08-26-2022 06:20 AM
Buy some front flares and section them in the middle. Why would you try to cut and reshape the wheel well? That would be a major pain even for an experience panel beater.
Dpmulvan 08-26-2022 06:23 AM
Folding over 1 inch on the lip would be the hardest way to go.
Dpmulvan 08-26-2022 06:26 AM
Originally Posted by DoMeister (Post 11781044)
Chris,
Reworking the lip would be the hardest way to go about it.
Dpmulvan 08-26-2022 06:36 AM
Small pie cuts these are exaggerated.http://forums.pelicanparts.com/uploa...1661524574.jpg
DoMeister 08-26-2022 06:45 AM
@Dpmulvan
That’s a fair comment. Have you seen this done?
Do turbo front flares have wider opening at the bottom at the sill area?
Is there a way to make this similar to standard opening?
Thx
Dpmulvan 08-26-2022 09:04 AM
Originally Posted by DoMeister (Post 11781109)
@Dpmulvan
Thx
You could actually add some pie shaped metal to your sc flares to bring them out an inch and be done, it will raise the wheel well a tiny bit but shouldn’t be noticeable. Messing with the actual wheel arch area with that 90degree lip would be a major pain and involve shrinking metal, tipping wheel work et. Are you attempting this yourself? Or hiring someone to do it? Do a search on YouTube I’m sure there’s a video on this subject.
Antonov 08-26-2022 09:37 AM
DPMotorsport offers a front fender that is 1" wider than stock and has the same fender line as factory flares that looks like it would be a good match for the rear. This is a solution that I've been looking at for quite some time as I too would really like to add about 1" to my front fenders without touching the rears.
Only downside is that it's only available in composite (Kevlar/CF). They do however make the same fender in a short-hood variant as well.
http://forums.pelicanparts.com/uploa...1661535406.jpg
chrisbalich 08-26-2022 10:14 AM
I did something very similar to my own front fenders. But mine aren't done, and they're still steel. Can't go wrong with DP.
Antonov 08-26-2022 10:52 AM
Nice. Also can't go wrong with self built & steel ;)
DoMeister 08-26-2022 11:10 AM
@Antonov - they are gorgeous, just what I want to achieve.
I found them online https://www.dp-motorsport.de/en/prod...r-911-f-model/ for anyone interested. They are referred to as DP11F
Of course, I have bought 2 replacement fenders, fixed issues with rust and petrol filler and converted them from G to F, throwing them out is not something I could face doing!
Really helpful though because now it’s clear as day that I’m on the right track… thx
shamrok 08-26-2022 11:33 AM
I couldn’t find the DP fenders on their site, got a link?
Antonov 08-26-2022 12:43 PM
SmileWavy
https://www.dp-motorsport.de/en/produkt/carrera-widebody-fender-left-for-911-f-model/
DoMeister 08-26-2022 01:53 PM
One of the key areas that would need to be replicated is the rounding at the top of the arch that meets the top of the fender. Is this achievable using the approach you suggest. Some more detail would be interesting to understand. Thanks
http://forums.pelicanparts.com/uploa...1661550622.jpg
Dpmulvan 08-26-2022 02:40 PM
After looking at a fender the pie idea is not going to work on a 911 fender without bigger rims. your going to have to make them from scratch or buy them. It’s a good idea though I might have to add them to the fenders I’m working on. If I make a pair I’ll take photos. You could also mock some up out of foam and make them out of carbon or fiberglass.
MIAdragon 08-26-2022 04:23 PM
That green car looks amazing.
shamrok 08-26-2022 09:44 PM
Originally Posted by Antonov (Post 11781446)
Thanks!
DoMeister 08-27-2022 04:21 AM
So doing a quick and dirty comparison between the DP motorsports vs 930 turbo shows a lot of similarities. The main differences i can spot are;
  1. 8” vs 9” turbo fender
  2. Thinner lip vs turbo’s thicker lip
  3. F model compatible vs G model cut turbo
So returning to an earlier post, the approach could be to use the turbo fender and modify to be similar to the DP motorsport fender. Approach could be;
  1. Remove 1 inch from the inside of the turbo fender panel before joining to the car or joining to the car and then remove 1 inch from the middle of the flare
  2. Trim the lip to match the SC rear fender lip
  3. Bash, bend and dolly into shape
There could be an argument for using the original SC lip but there is potentially a lot of welding and heat around a fairly small area which can’t be good… Thoughts?
http://forums.pelicanparts.com/uploa...1661602728.jpg
http://forums.pelicanparts.com/uploa...1661602750.jpg
