Counterclockwise?
Any windshield installers here?
I have my 86 at the Porsche dealer for a windshield. The first installer did a terrible job and used adhesive. Now it's back there again and another installer is giving it a go. He is having a hard time not having gaps where the seal is against the car.
Is there a trick to it?
Rod
1986 Carrera
2001 996TT
Old 09-12-2022, 01:12 PM
Yes, there is a method to get the corner of the rubber pushed into the corner of the frame. There are many threads on this if you search. I use a notched piece of wood and a hammer to push the metal insert in the rubber to drive it outward into the corners.
Hope this helps,
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 09-12-2022, 01:22 PM
tholyoak's Avatar
In addition to the method stated by Rahl, the factory also used dum-dum, strip-caulk, whatever you want to call it to allow the seal to fit properly in the corners.
-Todd
1989 911 Targa
Old 09-12-2022, 01:39 PM
I do them myself, no help, with dum-dum in the corners, silicone spray and parachute cord. Long arms help. The glass shop gets rears with the annoying wiring and targa rears.
206 637 4071
Old 09-12-2022, 02:50 PM
Counterclockwise?
So I should tell the dealer they need some dum-dum? Lol
Old 09-12-2022, 03:41 PM
Full Send Society
I did both front and back (with the defrost wires) by myself. Not that hard when you understand the process.
Here’s my write up (post 929 in my thread)
When Well Enough Can't Be Left Alone; Backdate, EFI/ITB, AC, and more!
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 09-12-2022, 03:48 PM
I’m about to install a new windshield in my ‘84. I think I understand the process after spending a few hours here and on You Tube (esp. the importance of properly shaping the trim to match the contours of the glass). Just not sure about how/where to place dum-dum in the corners. Anyone have a photo showing how that should be done?
Old 09-12-2022, 05:12 PM
tholyoak's Avatar
Guess I'm a sucker for punishment, I even do the targa rear by myself.
Todd
1989 911 Targa
Old 09-12-2022, 05:26 PM
Placing the rubbers seals in the sun for a few hours helps relax the seal. Even with a seal at room temperature, it retains a lot of memory from the pack and doesn’t want to conform to its new shape as easily as one that is warm.
1986 3.2 Carrera
Old 09-12-2022, 06:42 PM
MBAtarga's Avatar
No mention by anyone as to which window seal to purchase? I know I've seen the recommendation previously but don't recall which model/part no.
Mark
'83 SC Targa - since 5/5/2001
Old 09-12-2022, 06:56 PM
Full Send Society
Genuine Porsche. Don’t bother with aftermarket seals. Just get the legit ones.
-Julian
Old 09-12-2022, 07:32 PM
Counterclockwise?
They are using a Porsche OEM seal.
Did I read somewhere that the seal for G body has been discontinued and substituted with a 964 seal?
Rod
1986 Carrera
2001 996TT
Old 09-13-2022, 06:50 AM
tholyoak's Avatar
The 964 seal was used on the 89 Carrera as well as the 964 during the 89 production run as they changed the flanges for front, side and rear window openings to 13mm vs 9mm due to production line changes (robots). This allowed for the redesign of the seals that didn't use a metal insert/trim frame. I think that some people have used these seals on earlier cars to get rid of the window trim. The earlier seal that requires the trim frame is still available.
-Todd
1989 911 Targa
Old 09-13-2022, 11:01 AM
famoroso's Avatar
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 09-16-2022, 08:29 PM
Counterclockwise?
Update.
Windshield was installed.
Service manager inspected it to find 1 corner not seated properly and a rip in the seal.
New seal has been ordered and they will try again.
So painful just knowing they are hacking at my car and have had it for a week.
Rod
1986 Carrera
2001 996TT
Old 09-19-2022, 06:48 AM
Counterclockwise?
Update.
They broke the windshield and need to order another one.
Rod
1986 Carrera
2001 996TT
Old 09-23-2022, 06:27 AM
Originally Posted by 911 Rod View Post
Update.
Front windshields are easy these guys don’t have a clue.
Old 09-23-2022, 06:37 AM
tholyoak's Avatar
Take the parts and run.
-Todd
1989 911 Targa
Old 09-23-2022, 06:39 AM
Counterclockwise?
Obviously.
-Todd
I could have done this, but couldn't find a place.
Rod
1986 Carrera
2001 996TT
Old 09-23-2022, 06:43 AM
