interior handle pushrod and bushing not sting in place!
it has become difficult to keep the bushing in its place in the back of the door handle where the lend of the pullrod enters it. the pullrod
pulls it out when i try to open the door. not sure if the pulled should have a bend (down at handle), which mine does not, or should it be greased at the pivot spot near the spring. it is hard to pull and pullrod pops out along with the little white bushing it goes into
Old 09-02-2022, 01:00 PM
Send a message via AIM to fintstone
In most cases, this mean the bushing is broken at the bottom and you need a new one. Photos?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-02-2022, 04:27 PM
i got it! i didn’t push the rod down fully into the clip.. working! thanks
Old 09-03-2022, 05:24 AM
Tags
handle
