biosurfer1's Avatar
Exhaust stud pre-removal strategy
i have read all of the horror stories of broken exhaust studs, and i have to replace some of my gaskets this weekend, anyone have any words of wisdom on what to do prior to removing them to reduce the chance of them breaking?
Old 02-14-2005, 01:55 PM
Jays72T's Avatar
You can try spraying with Liquid Wrench (or something similar) everyday until the weekend, letting it really soak in and you might get them off.
Another method you can try is to used a torch, get them red hot, and apperently they will come right off. I have never tried this but know some people who have and they had no problems.
Good luck.
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 02-14-2005, 02:24 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
Do a search for threads here and on Rennlist. Also PB Blaster and definitely lots of heat to get them loose. If you don't have oxyacetylene around then pick up one the MAPP torches. Obviously easier to try and work'em out, than trying to drill them out after snapping. Good luck.
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 02-14-2005, 02:44 PM
ecm911's Avatar
biosurfer,
Do you have a broken stud?
If you are trying to find out how to avoid breaking one , there are many threads on this bbs addressing this issue. if you look, may even see the same question from me a few months.
If the latter - I have some advice - SPRAY and HEAT.
Find posts from John walker on this topic, before you attempt.
I follwed his directions ( cycle heat - cold 4 times- after soaking ( I mean soaking) and was succesful with out breaking any studs.
Earl
PS - engine in car?
78 SC Coupe
93 RSA (Gone)
Old 02-14-2005, 02:56 PM
KobaltBlau's Avatar
the wurth rost-off ice looks good:
http://www.wurthusa.com/en/catalog/product.php?path=04.0120.jpg
fyi, if you don't have an acetylene set you can use a mapp gas tank with a propane torch head.
Andy
Old 02-14-2005, 02:59 PM
biosurfer1's Avatar
no, no broken studs, i just want to limit the chance of breaking one this weekend when i take them out
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 02-14-2005, 03:01 PM
Hi I have removed mine,and you should try this. Heat the bolt red and then spray water on the bolt, it will expend the metal and then be easy to remove. If there still deficult to remove heat them again, be patient.
Daniel
Old 02-14-2005, 03:02 PM
Thought's what I said.
I don't know that I would try this for a number of reasons. You may change the steel's hardness by rapid water quenching and make it more susceptible to snapping off. You may crack something you don't want to by quenching. Any rust and corrosion will be broke by solvents like PB Blaster, then heating and cooling. And take your time with the process.
regards,
Old 02-14-2005, 03:03 PM
biosurfer1's Avatar
thanks for the ideas, i figured trying to take them out without any prep wasnt the best idea.
2006 Lexus LS430 ML
Old 02-14-2005, 03:04 PM
ecm911's Avatar
Having done this succesfully with no prior exprience, i would suggest you review the posts here and through out this BBS.
I removed 3 nuts without heat, just tried with vert liitle force. That being said, after using a torch to remove the rest, I would not even try to remove aby without heat. HEAT is your friend!!!
Again look for threads there are many - if you do it most times they come off with very little effort. many of mine came of with two fingers on the wrench!!!
Sray with a good rsut buster everyday from now until you try to remove.
Get a torch, the hotest one you can get. I use actelene!
The propane , etc are not hot enough.
Then as Daniel describes Heat /cool , etc four times each nut before you try to loosen, etc.
Good Luck!!
Earl
78 SC Coupe
93 RSA (Gone)
Old 02-14-2005, 03:11 PM
just get the nut hot with oxy/ acetylene and quickly remove it while it's hot. have all the removal tools ready. the heat expands the nut, so why cool it and make it seize again?
206 637 4071
Old 02-14-2005, 03:23 PM
KobaltBlau's Avatar
yeah, I loaded the page a while before I replied.
Andy
Old 02-14-2005, 03:30 PM
Senior Member
Superman's Avatar
John and Earl are correct. And let me give you a little tip. JW is a man of few words, but each word is meaningful. I visit his shop and chat with him, and I have stopped daydreaming during these chats. At least twice I have failed to listen carefully to his suggestions, and paid a price both times.
Here, JW is saying to use heat, which is what Earl said. John is additionally saying to get everything ready and quickly heat the nut so that it is CHERRY RED. Then just as quickly but carefully, place the tool on the nut and turn it off. This will work. You may need to rent an oxy/acetylene setup, but it's WORTH IT. You have been warned.
Mocha 1978 911SC. "Coco"
Old 02-14-2005, 05:10 PM
David's Avatar
Use heat, acetelyne (best) or MAPP (2nd best), nothing else will prevent it from breaking if it's going to go and even then it's a crapshoot. At the machine shop where I work, the machinists swear that melting bees wax into the hot threads before turning helps.
Old 02-14-2005, 05:32 PM
Noel's Avatar
I say cut the nuts with a dremal tool and then pry them off. Just replace with new hardware afer you clean up the studs.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 02-14-2005, 05:45 PM
KobaltBlau's Avatar
anybody agree with Noel? that's interesting!
Andy
Old 02-14-2005, 06:07 PM
"I say cut the nuts with a dremal tool and then pry them off. Just replace with new hardware afer you clean up the studs."
Have you ever actually tried to do this?
The method outlined by John Walker has the least risk.
Old 02-14-2005, 06:14 PM
Noel's Avatar
I haven't tried this on the heat exchangers, but with other nuts. If you search the archives, others have tried it with sucess. It makes sense. Just cut through the nut enough where you can slip a screwdriver in to pry the nut open. Obviously, you only want to cut into the nut and not into the stud. I would also cut the nut on two sides.
In my mind, the risk of either method is the same, but since I don't have an Oxy torch, I'm using the dremal method when I take mine off. However, that is a late 05 project.
Old 02-15-2005, 05:22 AM
MAGA
Tim Hancock's Avatar
Anyone who has actually used an Acetylene torch (AKA Hotwrench) knows that this is the easiest, fastest, surest method of removal of any nut that is siezed. I know some have gotten lucky with penetrants and whatnot, but even one broken stud and you are in for a long repair.
Unless you recently had it apart and used Never-Sieze on the threads,
USE AN OXY-ACETELYNE TORCH, heat the nut till it is red hot then turn the nut till it sticks, then heat again, repeat and eventually the nut is off and very little force is used. It is really quite simple if you follow this procedure.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 02-15-2005, 05:35 AM
"I'm using the dremal method"
It will be interesting to read your report on the attempt. Cutting off the barrel nuts that are typically accessed through tubes that pass through the heat exchanger shrouds will be a challenge.
Old 02-15-2005, 05:39 AM
