LinkBack | Thread Tools | Rate Thread |
After the next project
seal for door (on top near mirror on outside) need part number - pics
I can't seem to find this small seal. It below the small stationary window in the door and is apart of the larger outer door trim which houses a large seal (rides against the window) and this smaller seal and this entire piece clips/snaps in.
Can someone help with part numbers? Thank you! Bryan ![]()
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
That's fond- just deglaze
Hi Bryan- That would be 90153193320- and the link from our host...
https://www.pelicanparts.com/More_Info/90153193320M136.htm?pn=901-531-933-20-M136&bt=Y&fs=0&SVSVSI= Hope this helps! (I cleaned & swapped the outer & inner channels a few years ago- sorely needed due to age/shrinking!) Cooking on a Porsche 911- The compound butter made the difference. https://www.youtube.com/watch?v=FvXBR50rH9E
Missed Approach Petra- 1986 Coupe Last edited by Missed Approach; 04-17-2020 at 08:44 PM.. |
Come on. That salmon looked perfect!
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
Thanks Robey5- I was really pleased with the catalytic converter as a cooking surface.
Missed Approach Petra- 1986 Coupe |
Guys, thanks very much. I found just found the number this morning as well and was about to post. Appreciate the help!!
Regards, Bryan
missed approach.. How did you replace the inner channel which slides along the glass? It seems too long and unsure where each ends fold into... the outside of the window channel the inside or if they need to be trimmed.. Thanks for any help!
Hi Bryan- If you are referring to 911-531-931-02 (Left) & 911-531-932-02-M136 (Right) this link was a huge help for me. I did not need to trim the pieces- they fit perfectly and sealed up the gaps due to shrinkage...
Door window seals
No, I'm referring to the inside one with felt on it... so some of it would eventually be underneath the finishing door cap once the door card was installed. inside of window.
Hi Bryan- The felt strips (with clips) 90153193520 (Left) and 90153193620 (Right) have the little metal button clips- I used a plastic trim tool to remove the old pieces and did not have to trim the new. They made a huge improvement in window operation. I married up the old with the new to make sure the button clips were all the same basic locations before pressing them into place.
We are still not talking about the same thing.. you are still outside the glass. I'm referring the seal inside the glass or inside the car. This the seal I am looking for help with. There isn't a left or right.. 2 per car same part number
Got it- Wrxnofx had the best recommendation...
Thanks, I am familiar with the way it goes in... meaning which side is in and out but I'm more concerned about each end and what goes under this seal vs. what this seal goes over... as there are other seals taking up that space. Appreciate you trying to help!!
part number 91153195101.
https://www.pelicanparts.com/catalog/SuperCat/0814/POR_0814_BDYSEL_pg3.htm#item5
felt seal.
I bought one of these from design 911 in uk was quite pricey and was told they are handed.
1984 3.2 cab india red 1970 1192 Volkswagen Beetle |
having same issue
is this the part you are referring to? i not sure if i’m getting the correct info. it’s located just below top of outer door panel between the window and inside of outer door panel . it looks like felt. that what you needed?.. me too!
did you find it? how did you install it.. if you did it yourself. thanks Quote:
