69-71S Hard Oil Line Brackets
Good morning,
I am seeking to convert my 71T to the S oil cooler setup. I will be using all period correct, factory parts. I have so far sourced the oil thermostat, and hard oil lines. My current head-hurter is sourcing the brackets which secure the brass oil tubes that go through the outer rocker to the inner rocker. Attached is a picture of the brackets I am looking for. Thanks for any and all help.
1971 911T Irish Green Coupe |
Everything is very open with a clear description of the issues. It was truly informative. Your website is very helpful. Many thanks for sharing!
You could fabricate some from larger diameter tubing. If you can't find originals. Isolate with rubber.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Thanks, that's what I may have to do if I can't locate these little buggers. They sure are hard to find!
