Rear Torsion bar cover problems....
I am in the process of putting my right rear suspension back together and am unable to get 2 of the bolt holes lined up with the body on the torsion bar. I had a very tough time getting the top 2 in. It is number 35 in the pic
Should I not drive it until these two are in?
86 Carrera Red/Black 80 SC Coupe Silver/Black (gone but not forgotten) |
Why aren't they lining up? Same plate, same car? You might put some pressure on the plate with a jack to align th holes, but I would first want to know why. You will be binding the bushing and me thinks it will want to start squeaking.
Yup same plate same car. I actually used the jack to line up the second hole. It is off by about 1.5 - 2 mm.. enough to not allow the bolt to catch the threads....
Undo all the bolts and take off the cover. Go to the hardware store and get 4 really long bolts and 4 medium sized bolts that have the same thread and pitch and the regular bolts (#37). Now slowly screw the cover on using the long bolts and then switch to the medium bolts when those fit. Everything should line up. I know it a pain to take everyting apart, but it should work.
Neil '73 911S targa |
Maybe something is not centered and that is keeping the cover from lining up right?
Neilk said it best. That's the way to do it. It's the only way to make sure you pull it down properly.
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
That cover should just slip on. Something is in the way. Is there any vehicle weight on the suspension? Unbolt the spring plate from the control arm. See if there was some misalignment there that caused something to tweek.
I wouldn't use any force to install the cover - that includes longer bolts to draw the cover on. Find out why it's not aligned. Sherwood |
Hey I have a question about that same cover plate.
I was under my car yesterday and noticed cracks in the cover plate. Is this something that should be handled right away? Or can I wait until I do the rest of my suspension upgrades?
Joe 1988 Carrera (Venetian Blue) |
You do not have permissi
Try grinding and sanding the inner cover surfaces to a smooth finish. That's a necessary step everytime.
And check that both holes are round. The bushing is going to have a slight interference fit, but it should be even all the way around so match the surfaces up before pressing it in. My suggestion would be to sand(light grit) a bevel on the bushing edge and use a temporary lube such as a very light coating of soap. |
Friend of Warren
It is rock hard rubber that has migrated from the bushing to the cover. I used sandpaper to clean out the covers.
Kurt V No more Porsches, but a revolving number of motorcycles. |
filo,
Are you certain the cracks are in the cover or on the welds to the body as shown in the link below? Rear Suspension Broken Weld Question
Daryl G. 1981 911 SC - sold 06/29/12 |
You could use a drill mounted drum sanding attachment, but covers are cheap used.
Recently Disbanded
i had the same problem. if the plate does not go on perfectly strait the holes wont line up. i just started each bolt a bit. then i was able to move the plate around with a rubber mallet to get them to line up. the trick is to leave them as loose as you can until you get all four bolts started.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Senior Member
This is very typical. Don't force anything: if you crossthread those internal threads you will be sorry.
Heat the cover and chisel it all out - every bit. Buy a sanding drum of 200 grit, then 400 grit and start with the coarse one. Get it round again. Then smooth it with the 400. Buy the bolts if the above doesn't work. Alternative is to file the holes i the plate a bit oblong: cheap fix but not the best suggestion. Best of luck, John
'78 Targa in Minerva Blue |
86 Carrera Red/Black 80 SC Coupe Silver/Black (gone but not forgotten) Last edited by 911Brian; 09-20-2004 at 11:37 AM.. |
If you insist on using force, try this. Insert a tapered drift punch through one of the torsion bar cover holes and into one of the threaded holes, maybe one of the lower holes, then use the punch as a lever to align the holes. Make sure the threads are clean and not damaged so you can thread the bolt by hand.
Hope this helps, Sherwood |
