Dansk ST rear flares
Hi,
Anyone have experience with the Dansk rear ST flares and/or know how much they are wider as the SC ?
I'm talking about these references: 591082a / 591081a.
I did mail Dansk but they couldn't give me the info needed.
02/1974 911 Targa project
Old 10-28-2024, 02:32 AM
Uncertifiable!!!
Uwon's Avatar
Have a look at my ST build where I used the Dansk flares. Pages3 and 5 are probably most relevant.
https://forums.pelicanparts.com/porsche-911-technical-forum/1126335-sweet-transplant.html
Allot depends on how much you press the flares against the existing body which can vary about an inch between a loose fit and a tight fit.
I can get you my final measurement for the rear tomorrow but not the front as it is still not assembled.
Hope this helps.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 10-29-2024, 08:09 PM
Thanks Johan, those look good. Measurements are not needed anymore as I ordered the rear flares already.
Will post the measurements when they arrive.
Old 10-30-2024, 01:10 AM
Finally my Dansk (left) ST flare arrived. Only left as I wanted to check if it's what I'm looking for. I didn't want to buy the set even when they are a cheaper alternative than other suppliers... And I don't mind waiting another couple of weeks for the right side one, there is enough to do on my Targa.
According to my measurements it's about 25mm (1") wider as my SC fenders.
But the highest point of the ST fender does sit 20mm (3/4") lower so the wheel will look more tucked on the same height. I'm not 100% certain if that should be the case but this is how the flare fits the best.
The SC lip measured from the inside fender is 305mm (12"), the ST 330mm (13").
@Johan, even though I said it woudn't be needed, your measurement would be nice to compare if you're still up for it.
Now for some pics:
The SC with the laser line
ST with the laser still at the SC height
A side view
Old 11-15-2024, 02:00 PM
skinnerd's Avatar
Originally Posted by Tomaszke View Post
Hi,
My guess would have been 1" wider than SC/RS flairs.
The ST cars easily ran 9/10" wheels on the back.
Not so easy on an SC/RS car.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 11-15-2024, 09:57 PM
RS flares measured 12”, RSR flares 14”, Doug is correct ST flare are about 13”. Signal yellow RSR and light yellow ST.
Old 11-16-2024, 09:28 AM
