| TeeJayHoward |
09-13-2022 11:24 AM |
Cam Sync Adaptor questions
Thinking about ignition solutions in between work-things.
1) For something like the Clewett cam sync adaptor, can it be installed with the engine still in the car, or do you need to pull the engine in order to drill the camshaft for the M5 bolt?
2) For something like the distributor cam sync modification, I'm assuming that they install a toothed gear with a missing tooth and a sensor in the dizzy (which spins at half speed, right?) to detect camshaft location. Is this accurate?
3) For a DIY solution, why has nobody stuck a hall-effect sensor in the (bored out) #1 spark plug hole of the distributor cap pointing down at the rotor and disabled the weights? Wouldn't this give you a home signal just like the dizzy mod? Is the pulse length too long to be useful (bad resolution?) for EFI ignition systems or something? (And if that's the case, why not just thin the rotor blade to solve it?) It seems like a fairly obvious solution but I've not heard of it ever used anywhere, and I'd figure "Replace your rotor and cap and there's your cam position sensor with zero effort" would be a major selling point. There's gotta be an obvious issue here that I'm missing.
edit: Hell, for the DIY idea, why not just replace the rotor with a missing-tooth wheel instead of thinning the blade, and there you go. Why do you have to send your dizzy in to get worked on at all?
