-   -   What stops an SC coupe window from lowering too far ? (http://forums.pelicanparts.com/porsche-911-technical-forum/1126374-what-stops-sc-coupe-window-lowering-too-far.html)
LJ851 09-14-2022 11:49 AM
Why does my SC coupe window lower too far ?
The passenger window of my ‘82 SC will lower well below the edge of the door, enough to run the roller off the window regulator track and get stuck down. I’ve read everything I can find and looked at all the parts in the door but can figure it out.
My drivers door looks the same to me but it stops just inside the door. What am I missing?
pampadori 09-14-2022 01:09 PM
I think targa/cabs are different than coupes. This thread might help: http://forums.pelicanparts.com/porsche-911-technical-forum/919700-does-your-passenger-window-go-all-way-down-83-targa.html
Dpmulvan 09-15-2022 05:11 AM
Broken pivot on the return spring.
Dpmulvan 09-15-2022 05:13 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/999739-window-regulator-spring-question.html
LJ851 09-15-2022 06:11 AM
I’ll check that pivot. The window rolls up and down normally as long as you don’t let it drop too low which I wouldn’t think it would do without a return spring.
Dpmulvan 09-15-2022 06:40 AM
There is an adjustment on the door under the door card.
http://forums.pelicanparts.com/uploa...1663249240.jpg
john walker's workshop 09-15-2022 06:51 AM
Cheap fix is a rubber pad strategically placed under the mechanism at the bottom of the door.
LJ851 09-15-2022 06:53 AM
That slot is an up travel adjustment for a targa I think, even though the Bentley manual shows it for a coupe. My door doesn’t even have that hole.
http://forums.pelicanparts.com/uploa...1663249855.jpg
The tail of the return spring is engaged in an intact pivot end.
http://forums.pelicanparts.com/uploa...1663249958.jpg
LJ851 09-15-2022 06:54 AM
What is the correct (expensive?) fix?
QueWhy 09-15-2022 08:18 AM
This was my issue.
LJ851 09-15-2022 08:25 AM
Originally Posted by QueWhy (Post 11797952)
This was my issue.
The center pin in the return spring or the one on the outside of the coil like in my picture?
LJ851 09-18-2022 02:34 PM
Can anyone shed some light on what is supposed to stopping the downward travel of the window?
LJ851 09-19-2022 11:51 AM
Well, I figured out what is going on. I am missing a stopper that is metal with a plastic insert. Here is a picture of the type of regulator I have with an arrow pointing towards the missing stopper.
If anyone has one of these on a junk regulator I would love to buy it. It’s for the passenger side.http://forums.pelicanparts.com/uploa...1663613437.jpg
proporsche 09-19-2022 12:21 PM
that is what i call very easy solution if you take your time..sorry i do not that piece..
Ivan
LJ851 09-19-2022 12:57 PM
Ivan
Thanks, Ivan. I agree, easy solution when I find the piece. What’s odd is that stopper does not show up on the PET connected to this coupe style regulator. I’m not 100% sure what parts to purchase new if even available.
Here is the stopper in action(window down) on my drivers door.
http://forums.pelicanparts.com/uploa...1663617373.jpg
LJ851 09-19-2022 01:16 PM
When I bought my car it came with doors that were partially reassembled and random bags of hardware and miscellaneous stuff that I have saved. Last night I looked for the stopper in all of the boxes and could not find it but apparently I overlooked one box. I just found the original stopper for the regulator !
So stoked !
http://forums.pelicanparts.com/uploa...1663618445.jpg
proporsche 09-19-2022 01:20 PM
So stoked !
cool ..like i said take your time;-)happy for ya
Ivan
