-   -   911 SC Dashboard Install Question (http://forums.pelicanparts.com/porsche-911-technical-forum/1126580-911-sc-dashboard-install-question.html)
Hlcass 09-17-2022 06:22 PM
I have a ‘79 SC with the typical warping leather dashboard issues. While my car is in the body shop getting a restoration, now was the time to pull the old warped dash out and replace as the windshield is out.
I found an excellent used vinyl dash here on this site.
My issue is this, I could not get the 2 studs that are on top of the instrument cluster to meet the holes they are meant for on the dash.
The 7 clips were lined up perfectly at the front (toward the windshield) as were the 5 studs along the front of the dashboard. But the studs are not forward enough to align with their holes.
I ended up removing the two studs and installing the dash without them.
My questions are:
- Is there a trick to it that I am missing?
- Is it okay to install the dash without the those studs?
:confused:
Thanks!! Mike
http://forums.pelicanparts.com/uploa...1663463056.jpg
http://forums.pelicanparts.com/uploa...1663463056.jpghttp://forums.pelicanparts.com/uploa...1663464072.jpg
walt 09-17-2022 08:09 PM
I had a similar problem and just used a round file to elongate the hole slightly.
Hlcass 09-17-2022 08:46 PM
Thanks Walt! May do the same.
r_towle 09-18-2022 08:45 AM
I assume that because of this variation in cars, the new replacement dash top from Porsche just eliminated those two studs.
My new dash did not have them, ordered from a Porsche dealer, via Porsche classic.
Hlcass 09-18-2022 10:30 AM
Thanks, that’s interesting. Maybe I will leave them out.
