911 steering wheel lock
Help! I have a 2008 911 Carrera S. The car will not start due to (Steering wheel lock) indicated in message bar. The steering wheel is not under any force preventing the locking pin from disengaging. From what I read; the locking pin should retract once the key is inserted but is not case here. Not sure if it's the key switch or locking module. thanks
you may want to try the 997 Forum, this one is for the older air cooled cars, which are completely different, than your.
