911sc stumbling/hesitation
My 1983 911sc has developed a drivability issue. This occurs when the engine is fully warmed up, as I don't rev the engine beyond 4000rpm when cold.
When Driving at WOT, the engine will exhibit an odd stumble or hesitation, as if misfiring. This will begin around 3500 to 4000rpm and go away usually north of 5000rpm. If I back off to maybe half or partial throttle, normal revving and power seems to resume. Seems more pronounced in 2nd through 5th gears. It has no issues or noticable problems with cold or warm starting, and the idle is smooth and even @950rpm. Thanks to all in advance for responding! I use 93 octane Mobil 1 exclusively. |
Must go faster...
I experienced something similar with my '78sc, but it only happened under load. It ended up being worn out ignition wires. The shielding had failed and the wires were arcing through the insulation. Once replaced, the problem went away and the car ran great!
Reiver
I'd go with that response....I've had similar low power experiences with older wires. One of those things often overlooked as we all go 'worse case scenario'.
Thanks for your replies. I hope it's something that simple. Is this something I can test for somehow before dropping $$ on parts? Also, I noticed the engine does not misfire or stumble when revving in neutral...
Reiver
Not sure, how long have you had the wires in place....one way is to pull the plug caps, shorten the wires and re attach...they tend to wear/burn at the cap connection...or if they are old just replace them.
When in neutral there is no load and even a weaker spark may do fine...a swag tho when at a distance but do the simple stuff first. |
I've experienced what you are describing. Once it was due to wires (brand new oem) and another time it was due to a bad coil.
I believe the wires are old, they appear to be the braided steel covered type, should I replace with OEM (expensive) or are the aftermarket type sold on PP's OK?
Fleabit peanut monkey
One way to check wire issues is to peer into your engine compartment when it is dark. Give your eyes time to adjust - about 5 minutes. You can then blip the throttle, etc to check against your symptoms. You may be surprised what you find.
The Clewitt Engineering wires are nice. I have them on my 81. Favorable price relative to OEM Berus, also. Folks speak highly of Magnecor.
1981 911SC Targa |
Rodek
This is my vry first post and I'm glad to see this thread as I'm having a similar issue on my 78 SC. I'll be checking those plug wires ASAP.
Guys I’m having the same issue , but it appeared after putting on Brand new wires “clewitt wires, new cap and rotor and back dating the heat. Could I have done some thing to the distributor … it was a tight fit back dating the heat and definitely put pressure on the cap while putting back on the distributor. I just bought a fuel filter going to install that this week.
I've mentioned this before, so please excuse me for repeating myself.
I thought it was a bit odd the distributor cap was hard to click down on one side. It turned out I had the plastic protector thing on the inside slightly crooked putting the cap on an angle. The SC ran fine when it was cold, and warm, but got a certain missfire when hot and under load. |
I changed the fuel filter no difference. If I hold a grounded screw driver to the distributor cap at near plug 1 it arcs. It does not arch if I hold the grounded screw driver near other plugs. Thoughts? Bad wires causing my problem ?
If no mistake been made on installation - I would say yes, make use of your right of return.
You can measure the cables with a multimeter for electrical resistance about 1k-5k ohms. If one or more wire is broken and if the insulation is broken the spark can arc through the insulation. If the measured ohm value is far higher or infinitive then it's an interruption. But: Even an interruption of a ignition wire must not mean that the spark won't go to the spark plug...therefore most interrutions on ignition wires are discovered only by measruing in case of several symptons...so the sparc can arc but not on some situations... Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 09-03-2022 at 05:30 AM.. |
What the ?
Same here it ended up being a bad spark plug boot and my 80SC.
SCWDP 73 1980 SC Harley Davidson Road King 9/11/01 FDNY/343 Never Forget! |
Lash
Lash 1963 356 T-6 Normal Coupe 1972 911 T Coupe ..... Sold 1972 911 S Targa ...... Sold 1980 911 SC Coupe Weissach |
I fixed the arcing at plug one. It was not the wires it was a faulty distributor cap. I put a new cap on and the arcing stopped . But I still have the hesitation at low rpm’s . I guess I’ll change the fuel pump and fuel accumulator. I hear loud wining sound coming from where the fuel fuel pump is . Is the fuel pump suppose to make a loud wining noise?
Couple of thoughts before you start randomly replacing parts:
- The accumulator is most likely fine unless it is leaking. I have found that cars that run well at load rarely have fuel pump issues. - Rotor good? Any play in the distributor shaft? - Is the ignition advancing the timing through the RPM range as it should? - Wires should be good now. Plugs OK? - Have you verified function of the injection system? Vacuum leaks? - Have you checked the spray pattern on the injectors? |
Yes there is play in the rotor shaft.
Not sure if the ignition is advancing through timing properly. Not sure if the plugs are good. Vacuum leaks are on my list. How do i check the spray pattern on injectors? Last edited by Linehand; 09-18-2022 at 07:30 PM.. |
Thinking back. It seemed to run a little smoother hot on a 100 degree day. Does that mean anything?
I will try and run down the check list and see that I can find, thank you fanaudical
