seat belt mounting
Is there some trick to installing the seat belt bracket on the b-pillar? The seat belt plastic cover (item 6) prevents access to the head of the bolt (item 7).
This is on a 1970 911. Thanks Last edited by sdmcoupe; 10-23-2022 at 04:08 PM.. |
Lift the plastic cover up, away from the shoulder belt strap.
Slide a THIN 11/16" open end wrench between the cover and the belt. Advance the wrench until you feel the bolt's head. Rotate the wrench & belt together until the wrench slips onto the hex head. Turn the wrench, belt & bolt around the bolt axis. |
