-   -   Turn signal won’t turn off after the turn (http://forums.pelicanparts.com/porsche-911-technical-forum/1127078-turn-signal-won-t-turn-off-after-turn.html)
JonnyDL 09-26-2022 01:15 PM
Ok, I’ve searched plenty about this, what I find is the high beam issues. My turn signals will only sometimes click off after straightening the steering wheel. Right side worse than left, but both are sporadic. Maybe a good contact cleaning? I can hear the click in the column only when they turn off. Dirty springs? Thanks
75 911s
fintstone 09-26-2022 01:21 PM
Probably the cancel tab on your steering wheel is broken or worn down (or a possibly a mismatch if you have an aftermarket wheel). Search for turn signal cancel. or cancel ring.
A lot depends on year and model of your car in this forum. You should share that in your post of signature block if you ask for help.
JonnyDL 09-26-2022 01:35 PM
Ok, I’ll dig in thank you.
75 911s
Uwon 09-27-2022 04:17 AM
Loose steering wheel hub will do it. After market steering wheel May do it. Extra think washers, a common fix for a wobbly steering wheel will certainly do it. Loose cancel switch will do it.
Patience.
Good luck.
Johan
