-   -   3.2 Motorpull Checklist/while I'm in there. (http://forums.pelicanparts.com/porsche-911-technical-forum/1127084-3-2-motorpull-checklist-while-im-there.html)
jmd88 09-26-2022 02:17 PM
Hey friends,
Doing a motor pull for service on my 3.2 (first one) and have the following list of todo's.
- Trans fluid flush (reccos on fluid?)
- Starter
- Slave Cyl
- Clutch Package (LW Pressure plate/clutch/flywheel resurface)
- Rear Main Seal
- Reseal of the upper section of case (oil related bits in the back)
- New oil pressure switch/seal
- Rennline valve covers/gaskets upgrade/hardware
- valve adjustment
- Trans mounts
- Motor Mounts
- Exhaust swap
- Air Filter upgrade
- New Oil "S" pipe
- New Oil Sender Unit
- Maybe a new oil cross line depending on how it comes apart during the pull
- Fresh plugs (plug wires are only 6 mons old)
- Fresh oil
- Maybe cap and rotor?
Is there additional preventative work I can do while it's out that's just easier while the engine is on the ground/stand? Engine has really good leak-down numbers and runs like a champ so not cracking the case or anything that intense. Just needs some oil - leaks resolved and a new clutch. So I figured I'd do the above while I was in there.
Want to make sure I don't miss any good opportunities - high ROI preventative fixes.
thanks much!
josephvman 09-26-2022 02:26 PM
New fuel lines if they are original, and new barrier a/c lines if you use the a/c or ever plan on upgrading it.
jmd88 09-26-2022 03:01 PM
Do you know which fuel lines in particular?
Or are you suggesting a full kit like this:
https://www.pelicanparts.com/More_Info/MASTUN.htm?pn=MAS-TUN
or this:
https://www.pelicanparts.com/More_Info/MASK3A.htm?pn=MAS-K3A
I've removed AC and will complete the removal during the pull (keeping all the parts, just never use AC)
thanks for the advice!
ahh911 09-27-2022 03:48 AM
Check engine cross member bar that both sides are not curled away or bent, didn't notice mine was twisted and ~ 5/8" out on one side, almost stripped a transmission mount trying to align it all. Figured it out, bought a new one and 5 min to align all 4 mounts vs hours of forcing. One of these things you might not notice.
New bar is 150$.
Sailkane 09-27-2022 04:08 AM
On engine oil thermostat
Throttle bell crank bushings
GaryR 09-27-2022 04:22 AM
Agree 100% with the fuel lines, talk to Tony here (boyt911sc).. IIRC he made me a set with SS flex covering for my race car, they were perfect.. chances are your tunnel line is OK but I replaced mine with one of the last OEM kits available. Tony can fix you up there also!
GH85Carrera 09-27-2022 08:10 AM
Look at the engine sound pad and insulation on the firewall. With the engine out is the time to replace it if it is a bit old and tired.
Also clean the engine bay while the engine is out.
And you for sure need the photo of yourself with your head sticking out of the engine compartment!
http://forums.pelicanparts.com/uploa...1664294949.jpg
jmd88 09-27-2022 08:57 AM
I 100% will be getting a photo like this. One of my favorites. Good suggestion on the Sound pad, thank you.
New bar is 150$.
I've been eyeing one of those sweet lightweight ones in the classifieds - might just need to do this. thanks!
jmd88 09-27-2022 08:58 AM
I've got the thermo - but not the bell crank bushings - ordering now!
thanks.
jmd88 09-27-2022 09:17 AM
I'll reach out to him - thank you!
Cujo911 09-27-2022 09:44 AM
Rear shocks (much easier access w/ engine out)
Oil lines for chain tensioners (mine were leaking)
Shifter bushings (they’re cheap since you’re placing an order anyways)
Oil filter and crush washers
Brake lines if they haven’t been replaced yet
Check condition of the tins surrounding motor (paint or replace if rusty)
Gasket that seals/surrounds the engine between the body
Shift coupling boot out of tunnel if cracked
CV boots
High temp spray adhesive for sound mat
-perfect opportunity to clean motor/engine bay
* Just had my engine out so I did most of the things (clutch, CV boots, remove/replace AC hoses, evap, drier, compressor, front condenser, motor fuel lines, added Pad Keeper in addition to new sound mat, ‘triangle of death’ parts, repaired cracked breather hoses that are NLA, etc.) mentioned in previous posts.
** changed out my speed/reference sensors and head temp sensor (easy access when motor is out but expensive)
*** Cheap items that you’ll probably need since you’re placing order (decklid strut clips that break, air/oil filters/ etc.). Make sure that you make a list and sleep on it. Save on shipping costs for the $5 parts that you remembered after the fact.
917_Langheck 09-27-2022 11:22 AM
I dont recall seeing Tony posting up fuel lines for sale, though he is fairly expert at the CIS. Len - BoxsterGT - and Paul - Mason_paul - on the other hand do frequently post up their offerings.
The other thing I would put on your list are the trailing arm pickup point bushings at the torsion tube since the transmission will be out of the way, making access much easier.
boyt911sc 09-27-2022 12:05 PM
Mistaken identity........
Gary,
The person who did your fuel line was not me. I fabricated and built CIS fuel lines but I don’t sell them. I recommend Len Cummings for fuel lines. Thanks for your recommendation but give the right person his due appreciation. Do you remember his name? Sorry, I don’t deserve to get any credit for the fuel line.
Tony
jmd88 09-27-2022 02:24 PM
Originally Posted by boyt911sc (Post 11808477)
Gary,
Tony
Thanks, I'll reach out to the folks above and see what I can learn.
NeedAJoker 09-27-2022 03:29 PM
Likely doing this same thing on my 3.2 this Winter, please post any tips/tricks/hiccups if you like to post progress.
rokemester 09-27-2022 05:14 PM
I suggest you change the trailing arm bushings while engine is out. It is extremely difficult to unbolt the trailing arms from the body. There is so much interference with engine and tranny in place. I would also consider replacing rear wheel bearings.
How are the fuel line connections up front to the fuel pump and gas tank? If leaking, the fuel lines in the tunnel may need to be replaced. Much easier when engine out.
Mr. Merk 09-28-2022 05:23 AM
Send the injectors out to be serviced.
Replace the CHT (updated two wire OEM) and crank reference sensors (Bosch BMW/944 part# is half price)
josephvman 09-28-2022 08:33 AM
I had a full fuel line kit installed, which I got from Griffiths, who also supplied the a/c lines and my a/c upgrade kit.
or this:
jmd88 09-28-2022 09:22 AM
Sorry for the dumb - CHT?
jmd88 09-28-2022 09:28 AM
CV boots
This is a great list, I've had boots done, have a zp shift linkage I just installed.
Any chance you have the parts list for that "Triangle of death". I've done much searching and heard it referenced a bunch but have not found a "And these are the things to fix to resolve the issue" so I've just been ordering everying on the back side of the motor. Would love a parts list if you've got one.\
Love the callout on cheap parts (decklid strut etc)!
thanks much.
Mr. Merk 09-28-2022 10:00 AM
Same, very nice parts
Cylinder Head Temp Sensor
930 606 915 00 CHT Sensor
0 261 210 002 Crank Reference Sensors x2
The crankcase breather tower gasket, thermostat O-ring, and oil pressure warning lamp switch are known as the “Triangle of Death”
930 107 791 02 Breather Plate Gasket
900 123 007 30 Seal ring
911 606 230 00 Oil Pressure Sender
Here's the other parts from my recent, intake-off, fuel line service:
930 110 197 14 Intake Manifold Gaskets
930 110 459 00 Intake Manifold Flanges
911 375 043 07 Clubsport Engine Mounts
9P1 129 487 Vacuum Line Connectors x2
928 573 727 02 Vacuum Hose Connector
Griffith Fuel Line set
We tested the fuel diaphragms, cleaned the throttle body and sent the injectors out for refurbishing.
jmd88 09-28-2022 06:45 PM
Exactly what I was looking for!
thanks much.
parts ordered.
