I have a pair of Zenith 40 TIN that I've started to rebuild. My first venture into carbs. I read the following in a Weber manual that I'm using to augment my understanding:
In looking at mine, I have one that seems pretty tight. Another has quite large gaps. What is this a symptom of? What are the potential fixes for this? Thanks.
You can loosen the collars at the bottom to allow the butterfly to reset. They should all open the same so no light all closed, minor light even on all with minor opening of the throttle.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
The butterflies all have to be aligned so they open the same. As mentioned above you can loosen the couplers to adjust. You can also look thru the transition holes after removing plug and make sure all the butterflies are aligned to the same spot.
john |
Check for broken throttle shaft coupler, Zeniths tend to suffer this problem.
Paul Abbott Weber service specialist www.PerformanceOriented.com |
| Tags |
| carburetors , zenith , zenith 40 tin |
