-   -   Jet Setting Sanity Check (http://forums.pelicanparts.com/porsche-911-technical-forum/1127357-jet-setting-sanity-check.html)
dennisv 10-01-2022 12:19 PM
I'm slowly learning about jets as I rebuild these Zenith 40 TIN carbs. Can I get a sanity check that I'm approaching this correct?
Main Jet: 115
My 120 gauge went into two of them with not much effort. I assume these are out of spec and need to be replace. Perhaps just as well. One doesn't even appear to have a hole, which I don't understand.
http://forums.pelicanparts.com/uploa...1664651865.jpg
http://forums.pelicanparts.com/uploa...1664651753.jpg
Air correction jet: 195
The carb pin gauges I bought only go to 1.5mm. I used the solid end of drill bit on the 195 and found 1/16th (1.6 mm) was a go and 5/64th (1.97mm) was a no go. Is this close enough to judge 195 jets are probably correct?
Idle fuel jet: 47.5
One of these seems so plugged or corroded I can't get a gauge in it. Can you replace a single jet, or are they meant to be done in sets?
Thanks for helping with my newbie carb questions.
icarp 10-01-2022 01:37 PM
one jet at a time is fine , just as long as all jets are the same measured size for both carbs
Ian
