Porsche Addict
Can I Simply Cut The Air Conditioner Belt?
I don’t use my air conditioning, (cracked hoses).
Can I cut the belt and just go on with life?
Maybe a dumb question, but?
Lawrence - 1986 911 Carrera Coupe Grand Prix White
1959 Land Rover Series II
1962 Volkswagen Sedan Ragtop
1959 Porsche 356A Coupe
1971 Porsche 911T coupe
Old 07-15-2023, 11:15 AM
Do it.
206 637 4071
Old 07-15-2023, 11:20 AM
Porsche Addict
Might be too technical of an answer?
Old 07-15-2023, 11:22 AM
spoke's Avatar
I removed the AC belt a long time ago. Tried to get it out from around the pulleys and engine tin and just could not wiggle it out. So I just cut the belt. An hour spent trying to remove a belt I will no longer be using before cutting it.
Find Spoke's LED Products:
www.spokeworksled.com
Old 07-15-2023, 11:32 AM
Cars and Cappuccino
tdw28210's Avatar
Yes, probably adds 70 HP. (kidding) but yes you can cut it.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
gearhead
I’m sure my memory of the weight is wrong, but I want to say if you remove it all it’s something like 60 lbs of junk.
In the meantime just cut the belt.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-15-2023, 11:47 AM
Not much drag on the engine unless that compressor was active, but the belt itself is serving no purpose anyway.
Remove the compressor, condenser and old lines and whatever you have up front. Easy enough to do and won’t take but a few hours.
Likely the hoses, seals and possibly condenser all leak on the original system, and might not be worth trying to rebuild/fix a so-so cooling.
Old 07-15-2023, 05:43 PM
If you keep using the AC blower for fresh air (not cooled), you may want to also disconnect the AC compressor clutch wire. You'll save a few amps (about three) and the compressor clutch coil won't be energized and heat up uselessly.
Old 07-16-2023, 01:50 AM
