Curious about how well the 3.0 sc should rev.
I watched most of this video earlier today.
https://www.youtube.com/watch?v=6-o6xWOWFU4&t=908s I couldn't help but notice how effortlessly that engine revved up to and beyond the red line, very close to 7000. I often wondered if my engine was underperforming as it really seems to struggle after I get to app. 5500 rpm. I've had it to redline but it was a struggle. Is there something I should look at? The cat has been replaced with a cheater pipe and the muffler has been replaced with a Borla 1 in 1 out. Could the muffler have something to do with the engine's reluctance to rev freely? Thanks, hughc |
Not sure about the muffler but mine will run easily to redline, mine is stock with a M&K cat bypass pipe.
I'm not sure what you mean by struggle, but it's possible that your throttle linkage needs adjustment. You just may not be getting full throttle. Lots of threads here about making adjustments, here is a good one:
http://forums.pelicanparts.com/porsche-911-technical-forum/537218-not-getting-full-throttle.html Mark |
KM to MPH
Looks like he drops to 3rd gear at 90kph (55mph) @ 3,800 RPM // accelerates with shift to 4th @ 160 kph (99 mph) @ 6,600 RPM // and continues to mash the pedal in 4th until 190 kph (118 mph) @ 6,200 RPM.
Seems like normal acceleration for an SC / 3.0 operating in it's power band (~4k to 6.5k RPM) to me. Drive it harder and enjoy... |
My SC's engine has been balanced and rev's like a Honda. Imagine that. a Porsche engine as good as a Honda.
Not that I make habit of it :rolleyes: but it rev's out to 9,000rpm I tend to not rev past 6,000rpm though. |
The exhaust back box depending on the type fitted can be very restrictive especialy when you get past 5k RPM, Mine is the 3.2, but I was very surprised at how much faster it would rev and hit the rev limiter when I removed the standard back box and fitted the Bisimoto rear exhaust, not for everyone I know but for the time I had it fitted to the car it was great fun!
As others have said; make sure you are getting full throttle before you suspect anything else, it is also important to have a good rotar arm, distributor cap, and leads for high rev's as they can deteriorate with age. Hope this helps. |
Is that really possible? wow |
Thanks guys,
I ever thought of the throttle linkage as I as thinking along the lines of anything but. I'll have a closer look at that as soon as time allows. The distributor was rebuilt 20K mi. ago and at that time the person that did the work (no names for now) advised that I set the timing at 16 to 20 BTDC. I've continued to set the timing as per Bentley but often wondered what would be the result of setting the timing at 16 to 20 BTDC. For now I'll deal with the throttle linkage and take it from there. thx again |
My 3.0 pulls hard and steady from 3500 to my self imposed 6500 rev line. You do have to work the gears right to be in that zone. Not unusual for me to downshift 2 gears to pass someone.
I've always been terrified of the redline... Is what he doing in the video alright??
The 911 loves to rev to redline !!!!
The better it is tuned the faster it revs . Ian Here is a 20 sec video of Kermit reving . https://www.youtube.com/watch?v=x6f0S2gz5ZQ short vid 130 mph 4th gear https://www.youtube.com/watch?v=F1_TpayD3D8 |
Kenzinger - there is a page in the owners manual that mentions maximum safe sustained (cruising) rpms.
It is something like 6300rpm. Briefly seeing 6800 Or more isn't gonna make it sweat. That being said, there are quite a few cars running around with broken valve springs so before you change your habits it might be worth pulling covers and confirming the springs are all intact. |
Check the mixture with a Lambda tool over the whole rev band. Mine (930/16 with lambda control unit) was laggy too over 4000 rpm. It was way too lean. I figured it out without a Lambda tool while bridging the csv manually via switch on the dash when I revved it over 4000rpm. So I found out that it was too lean and checked and adjusted the sensor plate height and have the fuel distributor and the wur overhauled.
The recent discussion in another thread here by having the csv controlled by micro switch on the throttle is not necessary when the CIS works as designed. Also check for vacuum leaks. They can also make the engine running lean. But such huge vacuum leaks influences the idle and cruise as well...how does the car starts? Thomas |
I don't understand. This is the third time I've tried replying to this thread so I hope this is the one that will stick.
Just to update on what's been happening I did check the throttle linkage and found some looseness and corrected that as best I could. The engine now revs up to red line somewhat quicker than before but not as quick as I'd like. But I can live with it if necessary. I did a leak down test and it is what it is. #1 showed 23%. #2 at 8%, #3 at 12%, #4 at 7%, #5 at 11% and #6 at 18%. Not the best , I know, but with 200K mi I won't fret about it too much. I'll test it again before next season. I did have an interesting conversation with Ian (icarp) and with his experience with these engines (see his videos above) I think his suggestions may be valid. 1. I should and will check the timing at 3500 rpm to see that it is at 30* BTDC. I'll adjust if necessary. That may be a valid point as I've only set the timing at idle. 2. Ian also mentioned, from his experience, the A/F ratio at WOT should be around 10 for maximum power, whereas my A/F instrument shows 12.5 at WOT. I'm not sure how to get it richer at WOT except maybe by some slight adjustment to the WUR which I am reluctant to mess with after my experience this past summer. Maybe someone with more experience can chime in. 3. Lastly, not knowing how the previous owners may have driven this vehicle, the valves could possibly have some carbon build up so Ian is recommending that I do several treatments of Seafoam and start to drive it like I stole it. An Italian tune up so to speak. So this is where I currently stand. Thanks to all of you that took the time to reply and offer comments/suggestions. hughc |
Regarding the AFR, the WOT number is meant to be 12.8 for max power to the point of max TQ rpm, then it can roll off .3 to .5 points to a total of 13.4 up to the redline for our aircooled aluminum cased engines
I think there was a miss understanding on the phone, sorry for that . I hope this helps . Make sure you pursue the ignition timing to the correct point 29* to 30* at 3300rpm ish . more timing past this point is not better unless the dyno says so. SO THE 12.5 YOU HAVE AT WOT IS CORRECT !!!!!!!! Ian |
I'll verify the timing as soon as the opportunity presents itself. hughc |
Hugh, have a helper depress the throttle pedal from in the car while you watch at the engine. After they floor it see if you can still open the throttle any further from the linkage. As the bushings wear out the pedal won't get full rotation at the throttle body and you'll lose throttle actuation (even the bushings in the tunnel can mess with this).
The previous owner of my SC thought it was down on power but the PPI showed that it was just this plus a bent throttle linkage. He was only getting about 70% throttle. Lots of other good advice here but I'd check this first. I know you said you checked the linkages for being tight but I'm not sure if you checked the full action from pedal to throttle. Ignore if you did. :) |
Ian's car revving adventure shows some faith in it's internals.
With the stock sc cams, it doesn't pull as hard past 6000, thankfully, I wouldn't have the guts to let it sit there at 7krpm. But it does pull very nicely to 6000rpm. I love the 81 cis, around the 10th year of cis development for the 911, so it'd better be the best. |
As I mentioned earlier, that made a difference and allowed me to reach red line, only Not as vigorously as I would like. I'll check the timing as per Ian's recommendation and see what that gives. If I had the resources I would like to swap out the cams for the ones Ian is using. But we all know swapping out the cams on a 200K mi engine could get very expensive and at this stage of the game I don't think I'm ready for that expenditure Thanks |
The throttle rod coupler can wear out and cause the throttle plate not fully opening.
https://www.pelicanparts.com/More_Info/91142308102.htm?pn=911-423-081-02-M260 |
If your car starts sputtering above a certain RPM, it's not throttle related. When does it sputter? Wide open throttle? Partial? Is it struggling to make enough power to move the car faster? All gears?
My money is on timing and fuel delivery. |
I think Hugh is reffering to a lazy feeling of the engine, not wanting to charge to redline . Not based on a missing of spark or fuel. If the advance is incorrect then that might do it . Ian |
If you have the time, Try removing the rear silencer just as an experiment, and see how much quicker the car gets to the red line,[yes it will be quite loud] if it has the original back box still in place it is surprising how restrictive it can be at high RPM.
Just a thought from my own experience.:) |
hughc |
Ian's first gear, speedo is in km/hr.
Thought it was 2nd in mph with different gearing. For first gear, it seems about right, looks similar to mine without being too picky. Someone stripped out cat, otherwise stock but I rebuilt top end. I think it pulls faster on mine till around 5800, then it would die off and Ian would blow by me. Phil |
There's a difference between revability in gear and in neutral
in neutral it depends on the rotating mass, cams, cr and exhaust, assuming all is nominal in gear it depends on gear ratio, which includes cwp and tire OD, rpm, and mass of the vehicle as well as the base items in the neutral rev scenario all cis 911s peak out hp at ~5500 hp and have heavy stock rubber clutch disks and tall gearing for fuel economy, none wil rev like an earlier engine w/ l/w clutch, fly wheel crank , cam timing and freer exhaust |
I've read/heard somewhere that you shouldn't rev the car too much in neutral. It should be under load when you are giving it some revs. |
I too have heard not to rev unless under load, but, when I switch to the next higher gear, lot's of times I'll push the clutch without releasing the gas pedal quickly enough and am pretty sure revs blip to 6krpm and above, freewheeling for a second, so, don't know what to say other than it happens from time to time, though not intentional. Come to think of it, every time you shift the engine is freewheeling? Shift properly at 6000rpm and the engine is freewheeling till the next gear and clutch pedal is back up.
In first gear, I don't have an lsd, if I punch the gas while rolling at 2000rpm the tire breaks traction by around 3000rpm. Second year on pilot sport all seasons, the decent ones, but they're getting worn. My point is, there is a lot of grit down there and it will fly to 6000rpm very quickly but you need some skill to keep the wheels from spinning. This is a rolling start, so no clutch drops whatsoever, I never thought the car would be this fast, maybe one day an lsd. |
M1 cams will provide GRUNT, but you need to give the engine the fuel it needs to make the power . I can get 0-60 in 5 secs flat if all the stars align .
1/4 mile in 14.0 at 101 mph and no burn out . all that at 8.0-1 comp ratio, my car is a street car, pulls great @ less than 3,000, it has to, to to get the low time numbers I beat the 2018 honda civic type R all 4 races as well as the WRRX STI subie . The feel of this cam is power and smooth with a charge at 4,000 to 7000 all this on a stock internals 3.0 , Stock spring plate clutch and steel pressure plate , SSI, dansk 70 mm sport muffler , 205/60/15 front , 225/60/15 rear tires , 45 mph 1st, 73 2nd ,103 3rd , 131 4th , 146 5th 28 mpg @80 mph, Porterfeild R4S brake pads , 228 hp at the crank ,in this config , on mustang eddy brake dyno, Just about the most fun ever ! Ian |
but even so relatively small changes in the engine rotating mass make noticeable differences in the slope of the rev acceleration curve. I recently experienced this in one of my 993 engines, It's a 3.6 993 in my '76 C3 w/ RS cams and custom Wong chip, Fabspeed headers etc, went from steel to an Aluminum Sport Clutch, The difference in mass was only a few pounds but the engine response both loaded and unloaded is phenomenal, there was a corresponding reduction in lug ability of the motor additionally, this motor revs considerably quicker than the 3,8RS in my 993 w/ much heavier g50 competition clutch set up As to revving in neutral, you do realize that from day one that these cars were timed at 6k rpm in neutral |
Maybe a touch more compression, cams were SC reworked, timing was set at the point where max valve to piston clearance at edge of timing spec. No cat, regular exhaust. 81sc usa. I don't know why it's contrary, but at 5800-6000 rpm the car gets a final deep breath, then backs down. It seems to pull harder than anywhere else at that final stretch, in 2nd it most noticable. Why is that 500 rpm more than others? Am I full of it? But there have been many times where this last blast arrives and I'm thinking wow, where did that come from? Some sort of deception, power back down, vacuum advance kicks back in and off it goes again? Don't think so, is there something with my timing and no cat pulling in more air showing a hint of what's possible? Don't know. I didn't mention this earlier figuring no one would believe me. I just did it again several times today. Phil |
My '82 Euro that's had the internals balanced, SSI's, doesn't back off at any revs. I've red lined it in top gear and it was keen to go faster. I wasn't.
Between 5700/5800 and 6000 it's a weird sensation, as if all of a sudden air is available freely and flows with ease through the engine, it just feels effortless at that point and it just whips the car along. (Breathy, is that a word?) Also, with free rev talk being the subject of this post, I hung around 6400 rpm the other day, there was a slight high frequency buzzing sound, very faint, that didn't appeal to me. |
After I replaced my rubber clutch that is... The rubber was good, but certainly not great |
torque peak/hp peak 1976 911 S 4000/5800 1976 Carrera 3.0 4200/6000 1978 US/ROW SC 4200/5500 1980 SC/RoW USA 4200/5500 1981-83 SC US 4200/5500 1981-83 SCRoW 4300/5500 |
My 1979 Euro engine had some low down torque, and ran out of steam at high revs. Well, not really ran out of steam but there eas no point in going over 5,000rpm because it didn't have any power gain.
But my 1982 Euro is a completely different beast. No low down power but the more you rev it the more power it gets. Red lining it in top gear it was feeling lively and wanted to go faster. No rubbber centered clutches. I think they were swapped out many decades ago. |
| All times are GMT -8. The time now is 05:51 AM. |
