Quarter Window Weather Seal Replacement
Is there a trick or tool that will help to ease the installation of the rubber seal? I'm having a hard time getting the seal to fit snuggly into the metal trim channel. The metal trim is not new. I've only removed the window and the old seal.
Part#: 901-543-901-20-M260 purchased from Pelican Parts Thanks, Ducky
Uncertifiable!!!
On my list for this winter….following
I’m sure somebody will chime in with suggestions. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
There is a guy on youtube named "Mike" that has a vid series restoring a longhood. He goes through putting these back together. I think he uses glycerine for all his seals.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
I found this in the early911sregistry forum.
https://www.early911sregistry.org/forums/showthread.php?98900-Pop-out-1-4-panel-window-seal-help-needed&highlight=quarter+window+seal+replacement Soak the seal in hot water for ~10 min to make it more pliable. Use Windex and spray the inner part of the seal. Apply pressure to snap the seal into the track of the window trim/frame. I will try this method and report back. |
I'm happy to report that the hot water soak plus Windex worked. It wasn't a cake walk, but I was able to get the seal to properly seat onto the frame channel. One tip is that you should start at the vertical edges and work toward the small rounded edge of the frame. This was done on my 72'.
Cheers! Ducky
Uncertifiable!!!
That is great news as I have four windows to do so this thread is very helpful.
I’m wondering if anybody has installed part #90154349320 which is a simple rubber piece that is supposed to be installed on the hinge side of the window. See pic below. ![]() Looking forward to some Pelican providing a guiding light. Cheers, Johan
As I recall, I used Armorall when I did mine, to make the rubber a bit slippery. It was still very difficult, and my fingers were quite sore the next day.
. The Windex spray works nicely and dry fairly quickly.
