‘87 3.2 no start - no fuel & ignition
Never had any start issues in my 13 years ownership, but now it is completely dead :
Starter turns fine Not a single pop from the engine Changed the DME relay, still the same No ignition and plugs completely dry, so no fuel either Suspect the immobilizer, so bypassed it with the emergency code : still the same Any suggestions what next ? |
Could be the speed and reference sensors or a cracked solder joint on your DME (not the relay, but the ECU itself). My guess would be the DME.
If you know someone in your area with a 3.2, you can put remove your DME, install it in their car; if it doesn't start, contact Sal Carcellar (sp?) on this site and he will re-solder your DME for a very reasonable charge. If it's the sensors, you can replace them yourself -- a tight fit but a DIY job. If you buy new sensors, buy the BMW counterparts -- same part, almost half the price. I wouldn't replace them unless you do some tests to determine if you really need to replace them. You can find info about testing from the archives -- I've since forgotten the details -- or someone will reply here with helpful info. Good luck!
1988 Carrera Coupe (3.2) 1987 Ferrari Mondial 1976 BMW 2002 |
Check if you have power to the DME (key ON -> ICV vibrates). Also check for fuel pressure (make sure the pump runs during cranking). If yes that rules out the alarm and DME relay.
Next, if fuel and spark are missing check the sensors with a DVM inside the 35 pin connector (Ohm: ~ 1000, In AC setting about 2V on speed sensor and very little on reference sensor when you crank) As others said, replacing these sensors is the next step unless your willing to buy a cheap (~30$) oscilloscope to measure sensor outputs while cranking. That will tell you if the sensor(s) are the issue. If the sensors are fine or replaced and still no fuel and no ignition this points towards the DME. And it's not a simple re-solder. The re-solder so many talk about addresses a poor or cracked connection for the ignition output. But if both fuel and spark signals are missing it's either the sensor decoder or the digital part of the DME (MCU, chip, watchdog, etc.) at fault.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
How are you verifying no ignition? I only ask because I mistakenly thought I had no spark and spent a lot of time chasing ghosts before I tested the fuel pump and discovered it was the culprit. 88 3.2 in my case. Testing the pump is a lot easier than replacing the crank and reference sensors.
Have been battling a no-start on my ‘87 3.2 for a couple of weeks. Turns over fine but won’t start. Replaced DME relay, reference & speed sensors but no luck. A bit of a newbie DYI shotgun approach. Did most of the recommended tests from the many no-start posts — seem to have spark and don’t seem to have fuel (I can jump the DME relay to get the fuel pump running but it doesn’t get power to the fuel pump fuse when key turned to on — only when cranking). I have not checked for fuel pressure or pulses at the injectors as I don’t have the tools to do so (yet) but I do not smell fuel.
The odd tests results I found were the following: 1. No ground at DME relay terminal 85b when cranking. 2. No voltage at AFM terminal 3 with the key on (not while cranking the engine). I suspected there may be an issue with the DME itself based on the above. Opened up the DME, cleaned up the boards a bit and found 2 electrical components (capacitors I think) that seem to be cracked and leaking. No obviously messed up solder joints to my untrained eye. The attached pic shows the concerning components, one of which is quite close to DME pin 20 which leads me to think this could be responsible for the problem with the ground at relay terminal 85b. Any thoughts? This may be a job for you, ischmitz. :-)
Otherwise, what is all that random moisture/residue? And ichmitz is the one that looked at my DME. He converted it to a 28 pin and also found one area of concern that he fixed.
1987 Porsche Carrera Coupe |
… and that’s the residue that’s left after I cleaned it up! I’ve only owned for four years, but it must have gotten wet previously. It’s a targa — of course it’s gotten wet!
This may help. A DME Relay that analyzes itself and displays visual indications.
https://www.ftech9.com/new-products/911-ssr-pp
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
@Bob: What you see is essentially rust on the wire-wound resistors that measure current for injectors and ignition output. While not pretty it is not root cause for your problem. I have seen these resistors in MUCH worse and they still work.
Pin 20 isn't related to these resistors at all. The DME relay needs to turn on even if your flywheel sensors are not working. The DME looks for the starter signal on pin 4. As soon as the key is in START position and the starter spins pin 4 gets 12V and that needs to turn the second stage of the DME relay on running the fuel pump and the O2 heater. Go methodically and verify you have power to the DME (key ON -> ICV needs to vibrate). If that isn't happening your alarm or immobilizer is at fault. Next, if you see +12V during cranking on pin 4 but no GND to the DME relay from pin 20 the DME is bad.
Start your diagnosis here; 911 3.2 No-Start Troubleshooting
At most a 15 minute effort! It's that simple. No need to remove the "connector cover".
Dave Last edited by mysocal911; 09-11-2022 at 12:16 PM.. |
You can use a regular testlight (bulb type), but the clip end is connected to 12V and NOT ground.
While cranking, touch each injector connector pin separately. You can disconnect the temp sensor and the light will flash brighter.
Dave |
The +12V will show up on the 35-pin DME connector w/o the DME connected to it. It is simply the same signal (T45, yellow wire) that also goes to the starter solenoid. But the GND from the DME low-side switch controlling the DME relay obviously only can be tested with the DME connected to the harness.
Thank you for all of the guidance. I love this forum! Will post the results a little bit later.
Well, I was expecting that a lack of ground from the DME’s pin 20 was going to be the problem, but my tests suggest otherwise. When cranking the engine I got voltage on DME pin 4 (about 9.7v) and then confirmed pin 20 was providing a ground. Suggests a problem in the wire between pin 20 and the DME relay’s terminal 85b which doesn’t show ground when cranking (if I understand correctly that pin 20 feeds ground to 85b).
Will follow up with mysocal911’s tests — probably Tuesday night after I’ve picked up the proper tools for the job. Couldn’t even find my incandescent 12v tester even though I know I had it just a couple of days ago. To say I’m frustrated would be an understatement, but I’m so appreciative of the help here. Thanks so much. |
A review from the initial post:
Just spray carb or brake cleaner into the air cleaner. If it runs, it's only a fuel problem. Quote:
Again, spray carb/brake cleaner into the air cleaner. Maybe a bad pump or Mickey Mouse alarm added. Quote:
Typical problem lately, last 5 years, has been the injector driver output, where the alternator over-charges the battery, i.e. > 18-20 volts. The other more common problem is an intermittent spark output. But you said you have spark, right?
Dave |
This thread is getting a bit confusing as we are now discussing no start issues for two different people...
