cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
89 Carrera high oil pressure
Hello,
89 Carrera seems to have unusually high oil pressure. Its about pegged most of the time. Is this normal for winter driving? Pics are after a hour drive (as hot as it gets). I change the oil in the spring with 20-50 and add a qt of 5-20 in the winter. Is this like a person with high blood pressure Anything to be concerned with other then possible needing to change the pressure sensor.
Chris
89 Carrera
Old 12-27-2022, 07:06 AM
It could just be a sensor ground fault.
Put the ignition key on RUN position but do not start the engine. If oil pressure gauge moves up to 1 bar or even more, then it is only a bad pressure sending unit. Or only a ground fault. Next check is to ohm the sending unit. When no pressure (engine stopped), resistance between sensor terminal and sensor body (or engine case) should be around 12 ohms.
Old 12-27-2022, 08:09 AM
Senior Member
Chris - that is not very different from what I see around those temps. As long as you are not pegged above 5 bar, not sure that you have an issue here.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 12-27-2022, 10:59 AM
Senior Member
In fact - there is a low mile 87 Carrera driving video on BAT right now that essentially has the same gauge readings as you show above.
Chris
Old 12-27-2022, 11:02 AM
cmcfaul's Avatar
Great
Just thougbt i would ask.
Had a 73 E and had the opposite iasue. Oil pressure would read about zero at isle whixh was normal for tbe 2.4.
Chris
Old 12-27-2022, 11:34 AM
Ctopher's Avatar
Mine is around the same, 87 with just shy of 60k.
CTopher
Old 12-27-2022, 01:13 PM
