-   -   Which parking brake part number do I need? (http://forums.pelicanparts.com/porsche-911-technical-forum/1127951-parking-brake-part-number-do-i-need.html)
TeeJayHoward 10-11-2022 01:06 PM
https://i.imgur.com/6vJBwQU.png
I'm looking for the parking brake setup with TWO heater controls and a manual throttle. There look to be several options in the '74-77 PET (pg 305, Ill 701-05), all of which start with 911-424-051. Does anyone know which part number is the one I need?
(In case it's needed, it's for an '81SC that's been converted to carbs.)
Showdown 10-11-2022 05:17 PM
I searched high and low for this exact part to no avail. I ended up having to make my own. I describe it here:
It involves some 3D printing, some welding and some metal fab but nothing difficult or precision.
http://forums.pelicanparts.com/porsche-911-technical-forum/1067600-2-7-x-faktory-pmo-efi-upgrade-18.html#post11818582
EC900 10-11-2022 07:40 PM
Looks to me like 911-424-051-09. Can’t say why -06 is titled as “with automatic heat” because that would be the option that had the dial knob in place of a lever in the center console. -09 has the 2 levers and switches that operates the eng. compartment blower fan.
Not sure if you already have the entire HB structure, but it looks like you just need the Lever, a longer collar bolt to couple onto the bracket (#2), then cable, etc to just add on what’s existing. If the above #-09 is the entire unit, it will still need everything to the engine. Try searching the dismantlers for the entire setup? Finding those loose parts could be iffy. http://forums.pelicanparts.com/uploa...1665542416.jpg
