1973 RS tribute roll cage Best Option?
Any recomendations of which bolt on, rear roll cages for a 1973 RS tribute?
Old 11-17-2022, 07:22 PM
Assuming it’s only for show and your not tracking the car, any bar in this shape would be accurate.
Old 11-18-2022, 06:31 AM
Tom '74 911's Avatar
If you're looking for just a bolt-in roll bar, I'd contact TRE Motorsports... https://tremotorsports.com/racing
Or Patrick Motorsports... https://patrickmotorsports.com
A welded-in solution, either a roll bar or a full cage is a different discussion!
Best,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 11-18-2022, 01:58 PM
skinnerd's Avatar
How will the car be used?
Do you need a roll bar that meets some kind of safety specs?
If not, any street roll bar is good.
I would opt for one with a horizontal bar if you want to use harnesses, like this one:
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 11-20-2022, 03:06 PM
Its only for street use. Thanks for replies!
Old 11-20-2022, 04:16 PM
