89 911 Targa Replacement -Upgrade Rear Speakers
I am planning on Replacement -Upgrade Rear Speakers which are the originals with Porsche Replacements PK964REARSPKR .
My question is simply do I Have to plan on removing the rear Shelf/ Deck to do so? My concern is what happens when I remove the four screws holding the originals down? What is holding those screws in...Is there a simple nut or some other retaining clip that might fall? Or is there a receiving clip/ nut that is attached to the rear shelf that I can just screw the new ones in with? Any advice would be much appreciated. Thank You All in Advance. Lee Last edited by Lees89911; 05-17-2021 at 07:29 AM.. Reason: title |
Completed the speaker upgrade. No Problem.
simple removal of Speaker Grill Covers and then removal of the original speakers held in place by 4 screws ( No problem reinstalling the new Speaker Plate- You Need to Purchase these mounting plates too (that hold the new designed speakers) as the retaining nuts are secured to the rear deck ( So no chance of falling in). |
Hi there - I'm about to do the same thing but I can't figure out how to dismantle the rear speaker grills. I removed the 4 mini bolts but can't figure out how to get the speaker out without breaking anything. Got any advice?
'69 911E Targa '87 Carerra Coupe |
I went down the path original of the "flat" shelf speaker enclosure but ultimately found an old mach type and pulled apart, installed new speakers and re-covered. The advantage being forward facing speakers (6x9) and a more solid "BOX" to allow the speakers to resonate
![]() Doesnt affect rear viability Now I have a 77 targa so cant speak to fitment for a coupe |
Hi, do you know if this speaker set up was a factory option or after market? David |
Aftermarket- Moch 1 is the brand.
Rutager West 1977 911S Targa Chocolate Brown |
Another option. I deleted my rear speakers and reupholstered the rear deck after filling the holes (easy). Then installed high end speakers with separate tweeters in the doors.
Perfectly acceptable sound for a topless car. |
http://forums.pelicanparts.com/porsche-911-technical-forum/1030760-door-cards.html
