help ID part
I had the 912E up on jackstands all last week, concours prepping whatever I could reach from under the car. When I finished, I took the car around the block to settle the suspension.
When I pulled back into the garage, this part was on the floor (passenger side, towards rear) I left early Sunday AM for the event and tried what I thought was all the systems that had plastic thingamagiggs holding/guiding any cables (heat, HVAC, windows, e-brake) Everything worked fine. (I checked the windows, latch release, and locking mechanism even though I did not remove the door panels.) Can anyone give me an idea as to where this part might have come from ? Thanks in advance Bill K http://forums.pelicanparts.com/uploa...1665598412.jpg http://forums.pelicanparts.com/uploa...1665598444.jpg http://forums.pelicanparts.com/uploa...1665598466.jpg http://forums.pelicanparts.com/uploa...1665598482.jpg |
$1 on door striker plastic. Only thing I can think of.
Edit: Yep, you can see the portion of the plastic that broke off: https://www.pelicanparts.com/More_Info/RENDH27.htm?pn=REN-DH27 |
Right you are David Inc.
Here's a pic of the driver's side striker - already in three pieces and ready to fall out. That piece took a pretty good beating over the course 46+ years ! http://forums.pelicanparts.com/uploa...1665601282.jpg Thanks for the link - $50.00 - :eek: Thanks, Bill K |
| All times are GMT -8. The time now is 02:12 PM. |
