911 SC versus 914-6
Ok here is the deal. I have a 914-6 with carbs on a 2.7 and I have a 77 911 with an 81 sc engine it. The 914-6 is 10 times faster and is basically a stock 2.7 with cis cams and the carbs. The sc motor is stock with cis. That all being said SHOULD this be? I figured they would be very comparible?
Major question is that at about 2000-3000 on the SC motoer surges and can't seem to get that surge out with mixture adjustments. Could The WUR be all my problem or maybe because I still am using the 77 fuel pump do it? I replaced the fuel filter yesterday and it did not do much. I have played with timeing with no big results. When I punch it it takes off but more like a 944 rather than a 911. I don't have alot to compare with as the only porsche around here besides mine are a 356 sc and a 400HP 930 turbo. I am sure that the 2 cars should be somewhat close?
Ben
Old 05-31-2003, 10:11 AM
Unregistered
sammyg2's Avatar
The SC isn't running right, when it is it will be faster than the 2.7
I've driven a 914 with a very well sorted out 2.7 with CIS, cams, some head work, headers, etc. My 911 is faster (in a straigt line).
Old 05-31-2003, 02:05 PM
TyFenn's Avatar
Is this sort of the same question as your other post?
We can share the women, we can share the wine - Jack Straw.
1970 911t w/3.0
1971 914 w/2.0
1987 300E
Old 05-31-2003, 02:08 PM
I know it is similar to my other post just thought this would draw some attention and maybe some help. You know sell it and people will come.
Ben
Old 05-31-2003, 07:30 PM
