cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
G50 question
89 Carrera with 5 speed G50
On the passenger side, with the wheel raised I can rotate the wheel back and forth about an inch before the the gears in the trans engage (do anything) (is this called lash?). I think the trans is getting loud and I am babying it. I just installed a non rubber disk clutch, could be the issue?
I also just replaced both half shafts / joints (the play is not coming from the CV's).
Is this anything to be concerned about? If yes, what's the fix
Thanks,
Chris
89 Carrera
Old 10-03-2022, 08:13 AM
Pretty normal, and G50s are kind of noisy anyway.
206 637 4071
Old 10-03-2022, 09:46 AM
Pretty sure mine's the same way. 190k on it. Been that way since I bought it 10 yrs ago. Never an issue or gotten worse.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 10-03-2022, 10:51 AM
gearhead
Probably nothing to worry about. If there’s a gearbox issue it will generally whine or howl. They don’t generally wear out quietly. It’s common to get a little anxious after doing the clutch, because now you can hear and feel it’s normal sounds more.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-03-2022, 12:14 PM
differential gears. normal.
The noise is likely something else. Is the noise more prevalent in any particular gear? Or goes away in a certain gear? Or on accel or decel?
Old 10-03-2022, 07:03 PM
cmcfaul's Avatar
It gets loud mostly in 5th gear under load. A grinding sound. have been living with it. but now that its getting cold and the windows up I hear it all the time. Changed gear oil twice, replaced CV's and trans / motor mounts.
Chris
Old 10-04-2022, 07:15 AM
gearhead
Grinding sound is bad. I’m guessing it’s CV or other item outside the gearbox given the recent work. Changing the clutch wouldn’t cause a grind inside the box.
1974 914 Bumble Bee
2009 Outback XT
Old 10-04-2022, 08:55 AM
Senior Member
Chris - haven't done my clutch yet, but did replace engine mounts with WEVO, and new tranny mount inserts. Also did the shifter bushings. Having read many threads, you may just be getting more noise from the clutch - mine transmits more noise, but nothing that others are not referencing as "normal." As JW offered, the G50 can be noisy, and after any repair we are naturally listening more intently.
As Matt offered, a couple new sounds led me to find a stripped bracket - that removed a rattly on bumps. And the latest was ID'd as the driver side outer CV boot split...so that will be replaced when the parts show up.
Also, cannot remember where I read if you have LSD, there can be some additional noise when you are backing up...but cannot reference.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 10-20-2022, 05:12 PM
