installing the front stabilizer bar
Hi,
found it fairly easy to install the front bar using 'pre spanner' device that I made from bent metal bar, some clamps and a chain. http://forums.pelicanparts.com/uploa...1666437275.jpg http://forums.pelicanparts.com/uploa...1666437600.jpg left side is pushed in really deep, right wheel is off and car lifted in front... then, when the right piece of the bar is nicely adjusted, I added a spanner from the front of the car pulling the bar in on the right side, while I had a spanner (what's the best English word for this...'strap band' ?) on the left piece of the bar to pull it a bit out of the new bushing. that "left pull out/right push in" made it possible to set the bar to the correct position, and install the underplate |
| All times are GMT -8. The time now is 08:22 AM. |
