I found an open connector in my porsche 911 3.2 1984
Hello,
I found an open connector in my engine bay. See the picture. Does somebody know what it is? Is it possible this can be the reason why i can't start the Porsche anymore?
Thanks a lot
Old 10-22-2022, 03:54 AM
rgrimm's Avatar
I replaced the heater fan in the engine compartment on my '84 and knocked a connector off. Wouldn't start...nothing.
Can't see the picture but if it's what I experienced there are three connectors behind the engine fan. Feel around for them and look for a plug laying on the engine tin below. I believe the plug is white.
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 10-22-2022, 12:26 PM
here is the picture
Old 10-22-2022, 01:52 PM
Does anybody know what is the function of this open connector?
Is it broken?
Where does it needs to be connected on?
Thanks a lot
Old 10-22-2022, 01:53 PM
Is your O2 sensor connected and functional? I would connect just upstream of the Catalytic Converter, which us under the area you photoed/referenced.
Old 10-22-2022, 01:56 PM
proporsche's Avatar
it is your oxygen sensor 3 way connector--which is broken off here..But that would not make your engine not to start..as said above check your 3 plugs on left of your engine
1985 911 with original 502 191 miles...808 198 km
Old 10-22-2022, 01:59 PM
Thanks a lot for the Reply. I will check the 3 plugs.
Old 10-22-2022, 02:14 PM
The 3 plugs are checked and ok.
I found the problem of bad starting and driving. The plug of the Air sensor valve was dirty inside. I clean the plug with contact-cleaner... and the problem was fixed. So, i want to remove the air-sensor-meter and clean everything very good. But i don't see any instructions on the internet how to remove the air-sensor-meter of a Porsche 911 3.2 1984. Does somebody has a procedure how to remove this air-sensor-meter?
Thanks,
Peter D'Affnay Porsche 911 Targa 1984
Old 10-25-2022, 05:39 AM
