-   -   a real quicky, PLEASE (http://forums.pelicanparts.com/porsche-911-technical-forum/112869-real-quicky-please.html)
fogcity 05-30-2003 10:03 PM
Going to be parking the 911 in airport long term parking for a few days. To discourage theft (although only a bit, I know) do I have to remove both battery terminals or can I just remove the negative one?
Thanks,
Ps - should you see a platinum Carrera in the parking lot, give it a smile and make sure no one is messing with it:)
fogcity 05-30-2003 10:29 PM
anybody up?
TYPE 901/05 05-30-2003 10:41 PM
put a wire in your pocket
pull the distributors coil wire, take it with you, and have a good trip. SmileWavy
Just don't forget to plug it back in when you get back. :rolleyes:
Shawn.
Emission 05-30-2003 10:47 PM
You can just pull one (negative wire). This will also prevent the battery from trickle discharge.
But, if you take the coil wire, they won't be able to simply re-attach the battery...(and, most likely, they won't have a spare).
Personally, I'd do both if you are worried.
TYPE 901/05 05-30-2003 11:11 PM
if one is good...than two is better...
Emission has Established your (E) mission. Please do not put the coil wire in your pocket as I mentioned before.
Airport security and all.:eek:
Two pelican heads are better than one.:)
Shawn.:p
fogcity 05-30-2003 11:23 PM
Cool, thanks. Hey, where do I find my coil wire?
I hope you smarties are still up
fogcity 05-30-2003 11:37 PM
Shawn, Emission: you guys still there?
DJB 05-30-2003 11:41 PM
It goes from the centre of your distributor to the coil.
TYPE 901/05 05-30-2003 11:43 PM
Oh noooo...
I am an early car guy. Mine has six going to to the engine's spark plugs and one going up and to the left...to a blue thing about the size of a 10oz can of juice...it's blue and has BOSCH written on it. Your in a....what SC...should be similar, the coil could be on the fan shroud though. Look for the one distributor wire that begins at the center and runs away from the rest of the spark plug wires. Later car guys...Help!!
Shawn.
fogcity 05-30-2003 11:44 PM
I think I can figure it out from here. Thanks, guys.
Emission 05-30-2003 11:52 PM
It has the yellow arrow aimed at it.
Have a safe trip!http://forums.pelicanparts.com/uploads/Coil Wire.jpg
Sonic dB 05-31-2003 12:07 AM
Or you could remove the DME relay from under the drivers seat....
TYPE 901/05 05-31-2003 12:19 AM
or...
1.) leave it at home.
2.) let your friend/family member drive it back home(and have loads of fun while your gone)
3.) flatten the tires and punch a hole in the fuel cell!:D
Shawn.
andyu911 05-31-2003 12:26 AM
How about the fuel pump relay?
TYPE 901/05 05-31-2003 01:57 AM
what do you guys do down there...
drive your p cars year round? Wow...I want to move there. Could I make a living down there if I bring my snow plow trucks and set up?
I wanna go to a restaurant and hang with super models, rock legends, and movie stars.
I guess I am an out cast. Park it at home doesn't work on this board. I will go back to my local northern lights watch and seal hunt board.
Shawn.:D
kellzey 05-31-2003 06:09 AM
Cool... Platinum colored 911 Carrera at the San Francisco airport left unattended.
Checklist...
1. Check battery connections
2. Bring distributor wire
3. Check DME relay (bring spare just in case)
Cool! Free 911. Woohooo! We're on our way.
Just kidding! Have a safe trip.
Regards,
Huey58 05-31-2003 07:38 AM
Just take a cab to the airport then you don't have to worry about it while your gone!!!!!!
pwd72s 05-31-2003 07:49 AM
I'll vote for the take a cab or have a friend deliver you option..
RoninLB 05-31-2003 08:30 AM
Re: a real quicky, PLEASE
Originally posted by fogcity
Going to be parking the 911 in airport long term parking for a few days. :)
why don't you ask around for info on how many cars are boosted from the airport every hour ..............Ron
Phoenix 05-31-2003 08:45 AM
Use an old trick my Dad used to do to keep customers from taking their cars home without paying using a second set of keys.
Pop off the distributer cap, remove the rotor, replace the cap.
(He used to do the same to me to keep me from borrowing our old beetle. I got wise and bought a spare rotor :-) )
autobonrun 05-31-2003 09:39 AM
I remove the fuel pump relay. Just remember where you put it.
ruf-porsche 05-31-2003 10:03 AM
Just put a set of keys in one of those magnetic box under one of the wheel well and I'll move your car so that people will think that the car is only park there for a short amount of time.
tiorio 06-01-2003 09:30 AM
Err, uh...
Ifin you have an alarm, don't disconnect the battery! Any alarm is better than no alarm. Take the coil wire with you as others have suggested. Also, get a club. Even though easily defeated it's a deterent to a thief who doesn't know or doesn't have the correct 'tools' to disable. I also recommend a cover. The more time a thief has to spend at your car, the more time for someone to notice his activities!
Cheers!
fogcity 06-03-2003 09:07 PM
My, God! I never knew so many people where as paranoid as me!
On any account, I made it back home and the car was just where I left it. (Although I couldn't remove the coil wire because it seemed to be clampted the sparkplug wires by some do-hickie. I did, however, pull the plug and just let it 'sit' atop the coil as if it was connected).
Are a lot of cars stolen from the airport parking lot?
ruf-porsche 06-04-2003 04:36 AM
I would think with all the security camera that are at the airports these days and the security personnel most professional car rhieves would stay away from airport.
Plus don't you have to pay for parking when you leave and that require the little ticket you got when you drove in and if you don't have the little ticket that may arouse additional suspicions.
Rick Lee 06-04-2003 04:53 AM
On my last trip to CA, I left my Carrera at BWI for a week, as I knew it would be a sight for sore eyes when I got back and would be itching for a nice hwy trip home. I brought my cover, ran the locking cable through it, put my truck club on AND (this is most important), I took my parking ticket WITH ME. That way, if anyone steals your car, they will not be able to get out of the lot without the ticket, or they will have to pay an outrageous amount to get out, which will probably stick in someone's mind later on, should you need to track them down. I always bring my ticket with me even for short term parking. Make it tough on the thief.
Joe Bob 06-04-2003 06:43 AM
Don't go anywhere.....stay in the car and jump the first person that comes near it.....:eek:
toolman 06-04-2003 06:49 PM
Wouldn't you have a ticket if you went to steal a Porsche, and had a junker to leave in its place?
