Mike80911's Avatar
Restoring rubber trim parts
Does anyone have any tips or tricks they could share to restore the shine to aged rubber trim pieces like the tail or impact bumpers? Besides the usual things that only temporarily ad shine to it is there any other ideas?
89 930 Cab Black
11 Cayenne
Old 10-23-2023, 07:53 AM
I applied car guys plastic restorer to my exterior rubber last year and it still looks pretty good.
1982 911SC
Old 10-23-2023, 08:03 AM
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 10-23-2023, 08:07 AM
Originally Posted by Dpmulvan View Post
I'm assuming you've used this on rubber trim? I've heard of this stuff before but in the context of industrial maintenance. Does it restore (or as close to) the original look of the rubber?
High quality metal, body and paint work
http://www.spiuserforum.com/index.php?threads/are-you-looking-for-a-shop-i-am-available-in-virginia.9030/
Old 10-23-2023, 08:15 AM
Burnin' Rubber
Koizumi's Avatar
For rubber trim, Gummi Pflege. It does “un-goo” gooey deteriorating natural rubber. It’s useful with weather seals etc.
Actual rubber that has a cosmetic aesthetic function, like the accordions or even the silly US bumper blocks… I still haven’t found an excellent solution. Armor All Outlast Plastic & Trim Restorer lasts about 6 months. Makes outside rubber trim like new but again lasts only 6 months or so.
Old 10-23-2023, 09:08 AM
Glycerine. Back to Black (glycerine basically).
206 637 4071
Old 10-23-2023, 10:07 AM
Use a panel prep to clean out the baked in dirt and junk... it's amazing what that step can do without drying out those pieces. THEN, put on a ceramic coating
New cars its cool, some people will be against a ceramic on any finish on an older car... but i've got an 87' Carrera that I've pretty much transformed A LOT of the interior surfaces without needing to replace them with the right detailing products
I'm in that business, you can google my user name, but not really trying to spam this forum with 'my brand'... but from EXPERIENCE, good products and process can save you so much money in doing 'aesthetic replacements'
Old 10-23-2023, 10:11 AM
I've tried a bunch of different trim renewer products but the only one I've found to last at all was the Cerakote Trim Coat. It's small wipes and they really do a good job of bringing the black colour back.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 10-23-2023, 11:41 AM
Exactly what I came to post. This stuff is great! Wear gloves and a respirator and let it dry before you come back to the car... this stuff is toxic, but my go to!
https://www.amazon.com/CERAKOTE-Ceramic-Trim-Coat-Kit/dp/B07SHJVK4G/ref=sr_1_4?crid=6XCNV0WOMQJP&keywords=cerakote+trim&qid=1698090809&s=automotive&sprefix=cerakote+trim%2Cautomotive%2C388&sr=1-4
Old 10-23-2023, 12:54 PM
Cerakote is good on hard plastics & rubber I would not use it on weatherstrips, FWIW.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 10-23-2023, 02:13 PM
Burnin' Rubber
Koizumi's Avatar
Would the cerakote stuff work on the big rear rubber bumpers?
Old 10-23-2023, 02:33 PM
Mike80911's Avatar
When I look up cerakote it states to use it on plastic trim. Is it also good for rubber?
Old 10-23-2023, 03:03 PM
They specifically state to not use it on weatherstrips & flexible rubber.
I have used it on the bumperettes (very hard rubber/plastic) on my 993 to great effect.
Old 10-23-2023, 03:19 PM
Yes I would only use on hard rubber... I did my front bumper moulding and my rear bumperettes.
Old 10-23-2023, 04:52 PM
Burnin' Rubber
Koizumi's Avatar
On a G-Body car? If so, I’ll buy it.
Old 10-23-2023, 05:10 PM
dtwa's Avatar
Lithium Trim Serum
1985 Carrera 3.2 • Prussian Blue Metallic
Old 10-23-2023, 05:13 PM
Dow Corning 111 silicone lubricant/non-hardening silicone sealant. Park the car in the sun and apply a liberal coat with fingers or rag to the desired items. Allow to soak in overnight. Wipe off any excess and lightly hand buff. Works miracles on flag mirror surrounds, weatherstripping, bumper moldings, etc. Is also a great assembly lube for O-rings and other rubber seals/gaskets.
Old 10-23-2023, 05:20 PM
47silver's Avatar
Glycerine works cvs has it.
Old 10-23-2023, 06:25 PM
Works great.
Old 10-24-2023, 04:07 PM
NextZett, the same German company that makes the famous Gummi Pfledge for rubber seals and trim, also makes a spray-on or wipe-on product named Aktiv Autobalsam for black plastic and rubber trim. I’ve used this product on all my cars and motorcycles for over 20 years with zero disappointments, hundreds of compliments, and a few trophies too.
Unlike some other products it does not contain any dyes and is not greasy or glossy. It maintains new plastic trim and will bring old trim back from the dead with repeated applications. Leaves a very natural satin-matte finish and does not easily rinse or wear off. Also does not seem to attract dust or become sticky. Highly recommended.
https://nextzettusa.com/vinyl-rubber-extra-16-9-oz/
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 10-24-2023, 10:15 PM
