Rebuilding Mechanical Chain Tensioners
All
I'm rebuilding the original chain tensioners on my 77 911S, started hearing a rattle on the right rear side of the engine. Both chain tensioners had safety collars but the one side that rattled had a blue safety collar (pictured) about 30% larger than the grey one on the other side. Just wondering if that could be the problem? Nevertheless, gonna rebuild both sides. If the idler arms look good then for a rebuild the only parts I need are rebuild kits, cover gaskets, chain ramps? Thanks Tony http://forums.pelicanparts.com/uploa...1667069448.jpg |
Truth be told, most times you only need the inner and outer o-rings on the aluminum disc and know the bleeding procedure. The outer o-ring usually blows out and air gets in. The check ball, seat and springs can live forever.
In summer '82, during a long trip, I fixed one of these in a parking lot with minimal tools and an O-ring that was close enough to function. It lasted throughout the rest of my ownership of that car. Agree you have a good plan.
Thank you to both.
Here is a drawing of Porsche tool to set height of divider piston after bleeding. http://forums.pelicanparts.com/uploa...1667145100.jpg
http://forums.pelicanparts.com/uploa...1667145144.jpg |
| All times are GMT -8. The time now is 02:05 AM. |
