left side dash smoke
88 Carrera cabriolet. I got stuck in traffic yesterday for about 45 minutes. Turned off
motor and set ignition to radio to listen while sitting. About 30 minutes in I noticed
lite smoke coming out of left corner of dash. turned off ignition and appered to stop
When traffic cleared I drove home and everything appeared to operate fine. Took out
gauges and looked for some sort of burn area and nothing. Then I tried to operate
the convertible top and nothing. I can hear the click when I push switch but nothing.
There is supposed to be a fuse somewhere near the fuse panel but I can't find. Can
anyone point me to fuse or what I can check next. The top lock light is on so switches
for open and close appear to be working. Any help would be appreciated.
Tks Herman
Old 10-29-2022, 01:39 PM
Full Send Society
Check your ignition switch- you’ll have to crawl under the dash or use a mirror/boroscope.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 10-29-2022, 03:30 PM
Footwell blowers smoke. usually they squeel for a while to let you know they're gonna croak some day.
206 637 4071
Old 10-29-2022, 05:35 PM
laft smoke
blower motors weren't on only the radio and ignition. Gonne get under dash tommorow
Old 10-30-2022, 02:32 PM
If you can recreate the situation while looking under the dash or removing gauges, try pointing a infrared thermometer around could highlight the circuit that’s getting too hot in the Accessory position #1 maybe even find smoke source again. If nothing obvious, try same in ignition Position #2. Check fuse panel #1 or #3 which I believe they would operate top. Switch could be bad and added draw to overheat circuit. Aftermarket radio? wired properly?
Old 10-31-2022, 12:05 PM
