front torsion bars
Hey fellow Porsche owners. I am having problems replacing my front torsion bars on my 74 911. I had to have front pan replaced, so had to take all suspension off. Got everything back on, slid the torsion bars into control arm, adjusted bolt, but when I lowered the car it just dropped to the ground like the torsion bars aren't there. I have tried this a couple of times. I can't find anything that can answer me why. I'm hoping someone out there can explain what I am doing wrong. Thanks. Dano911
Are you starting with the control arm at full droop?
Measure the angle @ full droop, then set the bars aprox the same on both sides. Set the adjusters half way, lower the car, measure the ride height . If you can't get the height you want then pull the rear cap off and move it one spline to go higher or lower , u can reference to the original Degrees Let us know if that helps Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 11-06-2022 at 06:57 AM.. |
You have the adjuster end cap installed, correct? Take some pictures.
